Is this the reason bolts 15 & 16 are barstewards to free off?
Both are open to the elements under the lower case.
Crud doesn't get in but moisture will attack and work it's way up the threads.
Filling with grease won't help as the warmth from the engine will probably make it runny
I plan putting a short bolt in with anti-seize on it to try and help prevent the buggers seizing in to see if it helps.
Engine Bolts 15 & 16
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Yamaha AS3 125cc 1978
Yamaha AS1 125cc 1979
Honda CX500
Honda MT125cc 1980
Yamaha TZ125G 1981-82
Zeger TC500cc 1983-84
Yamaha RD500LC 1985-87
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Re: Engine Bolts 15 & 16
I would not think the grease would run out. Use it on my exhaust o rings on the TZ and it stays put. Use it and anti seize
Rather than button heads, I used regular capheads for these 2 bolts.
The larger Allen key hex should make removal easier.
They were a close fit regarding clearance on the increased head height, but on my engine, there was clearance (just).
