Strange twist with the usual brake upgrade
smokamoto
#1 Post by smokamoto » Mon Aug 28, 2023 2:08 pm
I finally did a typical front brake upgrade using early R1/FZ1 calipers & master cylinder with EBC floating rotors which many have done with no issues (far as I know). I ordered caliper adapters from NK Racing which are beautiful to behold.
Once installed I saw that the calipers were not centered on the rotors with 0.120” gap on one side & 0.0015” on the other. I wrote to Nigel who couldn’t understand what the issue was and that he’d sold dozens of these for over 20 years, which I’m aware. He had me measure the distance between rotor outside faces & I sent him 151mm. He said that they should be 131mm but then told me that was the spec for the RZ350 (never did say what the 500 should be).
Anyway, I sent the adapters back to England & he removed 0.055” off the insides to move the calipers out. After a month of returning/fixing/receiving, the final product fits much better, at least something I can live with.
Anyone else ever have this problem?
rz500guytexas
Re: Strange twist with the usual brake upgrade
#2 Post by rz500guytexas » Tue Aug 29, 2023 10:54 am
I would think anything that you would adapt to a different motorcycle will need adjusted or modified. Good to hear he knew what to do and did it. Last thing I want to question would be brakes and then suspension. In that order
smokamoto
#3 Post by smokamoto » Tue Aug 29, 2023 1:20 pm
I agree, it’s just strange that he’d never had an issue and it was just my set up that was way off, go figure :shock:
tacky1
#4 Post by tacky1 » Wed Aug 30, 2023 2:18 am
That is strange, I had the very same setup on one of mine and zero probs with it, Lined up perfectly....
smokamoto
#5 Post by smokamoto » Wed Aug 30, 2023 3:49 am
That’s good tacky, glad they bolted on for you with no issues, and your bike looks sweet!
Twinsport
#6 Post by Twinsport » Thu Aug 31, 2023 1:06 am
When Nigel made mine (maybe 15 years ago), I sent the R1 discs and calibers to him, to make sure that the meassurements were correct.
I wonder if the first set of adapters he made was for me?
They did fit straight on, but they are not as smart looking at the more recent ones.
/Steen
smokamoto
#7 Post by smokamoto » Thu Aug 31, 2023 3:49 am
Thanks Steen, I do recall your set up, even had a photo of it, maybe I still do :smile:
