help me, for airtech yzr 500 gp
- Contact:
ok, my contact whit airtech, is Dutch, ok verry cool.
well i want the upper body
http://www.airtech-streamlining.com/yamaz/90yzr50.htm
but the reply mailis:
"Hi Guillaume,
I just talked to the tech. The YZR500 parts will absolutely not fit on the RZ500, only the tail section. A better start for fitting on the RZ500 would be the YZR350 conversion front fairing
http://www.airtech-streamlining.com/yamaz/YZR350.htm
You will have to widen the belly pan and modify the fairing for carburetor clearance but it has been done.
Regards
Dutch"
i don't want body yzr350, tstststtssts i want a 500
ok, please, who have information for my ?
tom ? please...
"Hi Guillaume,
Regards
Dutch"
tom ? please...
- Contact:
GGggggrrrrr i want this
[img][img]http://apu.mabul.org/up/apu/2008/05/07/ ... 9zzfl7.jpg[/img][/img]
ps: i don't want the girl, I already have it
Hi,
Try the 1991/92 Wayne Rainey YZR500 fairing - it will be much easier to fit - you will either have to lose the carb air boxes, or re-profile the radiator ducts - in addition you will have to cut and widen the belly pan by about 5cm (2 inches) - oil tank and radiator overflow tank will also need replacing/re-locating - not easy - but possible - take a look at Wolfgang's bike - On my bike I chose to re-profile the radiator ducts and keep the standard air-boxes.
Sadly the company that I bought my 91/92 YZR500 fairing from have gone out of business - but there must be other companies that make them. - hopefully someone here will advise you on this.
- Contact:
Hi Tom, tank's for this reply, ok, so there was a lot of modification ?rztom wrote:^^ .... I'd have to agree with that assessment, Guillaume....
Anyone I know who has tried that fitment ended up having to do some cutting and custom body work. The RZ/RD series is just a bit wider than a YZR....
see you
- Contact:
Hi rd84rd84 wrote:Hi,
ok, well my bike is sp
- Contact:
Hi, Gusgus wrote:Gillaume, which part do you need? the top only. I have a complete set of YZR body work thats never been mounted I wonder how much cussin would go on if I had some sets made.
i want everything !
- upper, left and right center side (with the big vents), with windscreen, and lower. please
I do not need a rear seat and front fender
could you mail me a some pics please ?
thank's
