Best 2 stroke injector oil
JackB
Re: Best 2 stroke injector oil
#16 Post by JackB » Sat Mar 17, 2018 6:12 pm
I have been using Maxima 927 which is a castor based oil and it burns clean as a whistle. I have never had any engine problems and I use it in all my twostroke stuff.
1984 Rz350, Wicked Toomey rep pipes, Dynojet kit,Zeel unit,Toomey Y boot filter.
RuZty
#17 Post by RuZty » Sun Mar 18, 2018 10:09 pm
927 smells nice, but from their website;
"For all carbureted 2-stroke gasoline engines; not intended for use in oil injection systems. Designed for high performance applications. Premix only formulation is safe for use at any OEM-recommended ratio. "
JackB
#18 Post by JackB » Mon Mar 19, 2018 7:43 am
I guess I missed the best "injector oil" part.
T.RexRacing
#19 Post by T.RexRacing » Mon Mar 19, 2018 7:54 am
Ah most riders don't want to mess with premix. I've considered and repeatedly rejected that for a long time. Lazy when it comes to gassing up I guess.
Salvador Dali
whyzee79
#20 Post by whyzee79 » Mon Mar 19, 2018 1:34 pm
Torco sucks for me!
pushstartrearset
#21 Post by pushstartrearset » Mon Mar 19, 2018 5:28 pm
Premixing @ 24:1 has always been a safe ratio (good for high speed freeway cruising) for when I premix...you may have to rejet as necessary! I also like the smell of Redline Race Synthetic (very partial to this oil, when i could afford to run 24:1 in the AC 400F, it was definitely liking the high rpm freeway speeds @ 80+ mph. Amsoil has always burnt clean in the exhaust ports and a decent injector oil.
If you are someone that want's your ports cleaner than normal, I'd go w/ Amsoil (LC or AC bike).
LC Cnd
#22 Post by LC Cnd » Mon Mar 19, 2018 9:14 pm
Bardahl is alright (if available), iPone if you want to make the public happy (sweet scent when it burns) but having good luck with Amsoil. I pre-mixed 35-1 for breaking and bumped it up to 40-1 & smokes slightly. Good stuff and cheaper than iPone.
Ardee
#23 Post by Ardee » Wed Mar 21, 2018 8:52 am
A link to some reading on oil for those interested.... you can spend days reading oil stuff
http://www.dragonfly75.com/motorbike/oil.html" onclick="window.open(this.href);return false;
