RZ vs LC clutch - forgive my failing memory
nokturnal
#1 Post by nokturnal » Fri Jul 13, 2018 9:45 am
Which parts if any interchange? plates/springs I am wondering about mainly. tia
:smt027
:smt017
JonW
Re: RZ vs LC clutch - forgive my failing memory
#2 Post by JonW » Fri Jul 13, 2018 10:52 am
different operating mechanism, but plates are close enough the same and springs will work in eachother, but part numbers are diff.
nokturnal
#3 Post by nokturnal » Fri Jul 13, 2018 11:13 am
Thansk Jon.
Just trying to figure out if I can simply buy an RZ rebuild kit (which is more available)
:smt017
tacky1
#4 Post by tacky1 » Fri Jul 13, 2018 5:58 pm
Banshee parts are really easy to come by, They fit... I run banshee billet baskets and plates etc
JonW
#5 Post by JonW » Fri Jul 13, 2018 8:18 pm
Yeah RZ/banshee or FZ600 plates for an upgrade etc
hondaror
#6 Post by hondaror » Sat Jul 14, 2018 4:19 am
TZ250 springs are wonderful.
Bare
#7 Post by Bare » Wed Aug 01, 2018 11:46 pm
Also.. Completely 100% unnecessary Best part of Yama 350s LC OR Rz is their light clutch action.
Adding Stoopid strong springs messes that.. Big Time.. For Zero actual reason .
IF one does a decent job of rebuilding their clutch and fitting Suitable frictions..
It's seriously unlikely one can build an engine able to slip the clutch.
If Not.. be happy while struggling with your clutch lever
hondaror
#8 Post by hondaror » Thu Aug 02, 2018 3:00 am
I wore out 3 sets of clutch springs until I installed the TZ springs. Once the bike is running, the clutch action is way easier. Pick your poison, I guess.
Hooligan
#9 Post by Hooligan » Fri Aug 10, 2018 1:28 pm
How do you wear out clutch springs? How do you even know they are worn out?
Plates and frictions I can see, but not the springs themselves.
'85 FZ750
two-stroke-brit
#10 Post by two-stroke-brit » Fri Aug 10, 2018 2:12 pm
Hooligan wrote:How do you wear out clutch springs? How do you even know they are worn out?
They have a tolerance on the overall length which decreases with fatigue. :smt023
mark
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
hondaror
#11 Post by hondaror » Sat Aug 11, 2018 4:18 am
You'll know when they are done. Your plates look great but you've got high rev slippage. Ask me how I know.
Bare
#12 Post by Bare » Sat Aug 25, 2018 12:56 pm
Friction thickness can be surprisingly Slight betwixt Brand new and worn out .
IMO lotsa slipping clutches are worn out frictions based.
Takes a decent micrometer to be sure .
Eyeballs isn't enough Unless they are completely destroyed
There are drop in Oversized (as opposed to Stock) 350 size frictions giving 30% More friction surface,, sourced from a whole slew of Yamas up to XJ 1100s ?
Then there is the slight basket machining possible to shoehorn in 8 frictions for even more stiction.
AS well as bespoke Race frictions ...that Will Not slip if passably assembled.
One can even fit those locker/weight gizmos if Truly worried
TZ springs were for their seriously unreliable Dry clutch setups, which were actually easy to pull , like our wet ones.. despite their heavier springs.
