RD350B sitting for 20 years precautions before starting?
steveloomis
Re: RD350B sitting for 20 years precautions before starting?
#151 Post by steveloomis » Sun Jun 15, 2014 7:29 pm
That item is NOT part of the bike's original tool kit but is a spark plug gap checker, adjuster, cleaner with a file to square up the center electrode..
aaronmvrider
#152 Post by aaronmvrider » Sun Jun 15, 2014 7:33 pm
cleaning jets and gapping plugs... perhaps
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
tobster
#153 Post by tobster » Mon Jun 16, 2014 9:12 am
definately a spark plug service tool and nothing to do with jets. A nice little find
patastinky
#154 Post by patastinky » Mon Jun 16, 2014 11:51 am
steveloomis wrote:That item is NOT part of the bike's original tool kit but is a spark plug gap checker, adjuster, cleaner with a file to square up the center electrode..
aaronmvrider wrote:cleaning jets and gapping plugs... perhaps
tobster wrote:definately a spark plug service tool and nothing to do with jets. A nice little find
Thanks Guys.. yeah its a sweet find. Fingers crossed; wrench time next week :) In the meantime i'm going to read up on the JETS and carb cleaning.
two-stroke-brit
#155 Post by two-stroke-brit » Mon Jun 16, 2014 1:34 pm
harbor freight do a small ultra sonic cleaner that will work with the carb bodys .
patastinky
#156 Post by patastinky » Mon Jun 16, 2014 9:43 pm
two-stroke-brit wrote:harbor freight do a small ultra sonic cleaner that will work with the carb bodys .
something like this http://www.harborfreight.com/ultrasonic ... -3305.html" onclick="window.open(this.href);return false; ?
that's going to work better than dipping them in chem'dip?
#157 Post by JonW » Mon Jun 16, 2014 9:55 pm
US'ing carbs will work better than soaking. you can use a small unit with a tall container in it, people say it works well.
patastinky
#158 Post by patastinky » Thu Jun 26, 2014 9:29 am
JonW wrote:US'ing carbs will work better than soaking. you can use a small unit with a tall container in it, people say it works well.
I've seen a few videos online of people using SIMPLE GREEN in their ultrasonic cleaning units. I think i'll get one i have some jewelry that could use some US'ing.
pushstartrearset
#159 Post by pushstartrearset » Thu Jun 26, 2014 12:56 pm
A small crock pot and Piston Kleen worked pretty well on my hard carbon deposits on the PV and safe for aluminum. I bet it works the same for carbs too. Military uses this stuff. The key is HEAT. The crock pot provides that in spades. Low setting preferably as this is most effective up to 185 degrees. Cold just takes longer and i want it done yesterday.
Redline Junkie
#160 Post by Redline Junkie » Thu Jun 26, 2014 1:31 pm
I use "Gunk" Hydro-Seal for carbs, PV, bolts.
1987 RZ350 Stock
1985 RZ350F basket case
1985 RZ500 Stock
#161 Post by JonW » Thu Jun 26, 2014 9:20 pm
Interesting people always say they use Simple Green for stuff, but that's a brand isnt it? Here we have about 5 different types of Simple Green, each are for cleaning something specific, so which one do people actually use I wonder?
patastinky
#162 Post by patastinky » Fri Apr 28, 2017 1:03 pm
Hi Everyone
Guess who's back after a three (3) year hiatus. Life happened, got married, bought a house and my wife and I had a baby. 8 months old now, born on my birthday of all things.
Slowly been saving up some money as well as making room in the garage for storing parts I remove off the bike. Here is a current picture of the bike. Nothing has been done to it yet. It's the same as it was three years ago. Image Image I'll be adding some shelving this weekend.
It's not much of an update, but I did get a battery for it. Bought a battery tender, acid and got the battery ready. Going to test electrical after the shelves are up. Than going to take a look at the carbs and peak down into the engine as mentioned earlier in the post by you guys.
Sent from my iPhone using Tapatalk Pro
