Turbocharged RZ350.
Makr
Re: Turbocharged RZ350.
#16 Post by Makr » Sat Mar 21, 2015 11:52 pm
Off Road wrote:Here's another one that i saw a while back.
Again, no info on the bike, just 1 pic.
This is Lewis Cooke's bike. Set a record last year which was good being the first year with RZ power and turbo.
lt1bird
#17 Post by lt1bird » Tue Mar 24, 2015 10:30 pm
you know...my turbo rz motor actually is very good...plenty of low end power.... with a rpm controlled boost controller you can make it more civil... without it the boost hits hard! im running upwards of 28LB at max but now im back to 13lbs and working my way up.. slow...... don't want to smoke it LOL
in a 2 stroke turbo you need to make a lot more boost than normal to make any power...
WildcardRacing
#18 Post by WildcardRacing » Wed Aug 16, 2017 4:02 pm
Hello,
New to the forum. Found this post doing a Google search (apologies for thread mining). Peaked my interest as this is my build. Pictures were taken in 2013 by Torco at Bonneville. I would be happy to answer just about any question you may have.
-Brandon
vonzipper
#19 Post by vonzipper » Wed Aug 16, 2017 4:12 pm
Welcome to the site, I have a few questions. It's a single turbo, did you combine the output of both exhausts into one to feed the turbo? And what boost pressure you running? What changes is required to the carbs?. Thanks
90 RZ350 Track bike.
86 RZ350 Stock daily runner.
84 DT200
84 RZ500
WildcardRacing
#20 Post by WildcardRacing » Wed Aug 16, 2017 5:42 pm
Its a 2-1 pipe with single expansion chamber. We can adjust from 8-28psi boost, currently running 15psi max. The carbs have several modifications to run blow through with alcohol. You must either enclose the carb or run boost to all vents, bowl, top and front of slide to fool the carb into thinking boost pressures are atmosphere. You must also increase fuel pressure as boost pressure rises. The alcohol mods include adding a second main circuit, and dramatically increasing jet sizing.
evan_calgary
#21 Post by evan_calgary » Wed Aug 16, 2017 6:00 pm
I would also be interested in getting some additional information on this.
Is there a reason you need to run alky with the boost?
Are there more pictures available somewhere?
This is quite the cool build.
Also, welcome!
vonzipper
#22 Post by vonzipper » Wed Aug 16, 2017 6:00 pm
WildcardRacing wrote:Its a 2-1 pipe with single expansion chamber. We can adjust from 8-28psi boost, currently running 15psi max. The carbs have several modifications to run blow through with alcohol. You must either enclose the carb or run boost to all vents, bowl, top and front of slide to fool the carb into thinking boost pressures are atmosphere. You must also increase fuel pressure as boost pressure rises. The alcohol mods include adding a second main circuit, and dramatically increasing jet sizing.
. Cool, what kind of speed does it do on the flats?
84 DT200
84 RZ500
evan_calgary
#23 Post by evan_calgary » Wed Aug 16, 2017 6:03 pm
From previous reading this is one way to get high efficiency out of a 2-stroke as you hit the pipe and the turbo is spooled at the same time.
Lewis Cooke = Lt1whatever? Hope not. LT sucked.
WildcardRacing
#24 Post by WildcardRacing » Wed Aug 16, 2017 6:25 pm
We've seen a peak of 147 mph but have yet to make two successful passes maintaining that speed accross the timed mile
WildcardRacing
#25 Post by WildcardRacing » Wed Aug 16, 2017 6:27 pm
It is geared for a peak of 167mph and will pull it, but we've been working on the fuel system a bit
Forzfed
#26 Post by Forzfed » Wed Aug 16, 2017 7:40 pm
Very nice! I have a couple turbo cars and love them. The cooling effect of alcohol is awesome. Do you have some more pics of the set up? Can't tell if you have an intercooler. What HP is it putting down? :smt004
90 RZ Race Bike
86 RZ daily driver
85 RZ low milage
WildcardRacing
#27 Post by WildcardRacing » Wed Aug 16, 2017 8:33 pm
I do but cant get them to load. Guess I need to get on photibucket. Non intercooled and makes 130+/- hp
whyzee79
#28 Post by whyzee79 » Thu Aug 17, 2017 12:01 pm
we need a youtube video so we can hear this beast run. Does anyone do nitrous on a bike? That would be a blast on a two stroke I bet. Sounds like a piston frying adventure. There was an H1 on ebay a while back with a cheater bottle bolted to the back.
evan_calgary
#29 Post by evan_calgary » Thu Aug 17, 2017 1:46 pm
Don't use photobucket.
If you don't have a hosting solution let one of us know and we can help out.
Pictures would be great to see!
WildcardRacing
#30 Post by WildcardRacing » Thu Aug 17, 2017 5:25 pm
I don't
