Turbocharged RZ350.
Turbocharged RZ350.
90 RZ350 Track bike.
86 RZ350 Stock daily runner.
84 DT200
84 RZ500
84 DT200
84 RZ500
Re: Turbocharged RZ350.
That's sick. i bet she sounds nasty!
On Norbos forum a member there is doing a turbo build, and posting as he does it.
How do you get pressure in a two stroke without just blowing everything straight out the exhaust?
1990 RD350 F2 1WT
My question is why? I'd think it's not good for much but going in a straight line.
You are probably correct Rory, its looks like its on the salt flats for record breaking speed runs.
84 DT200
84 RZ500
84 DT200
84 RZ500
Well now, that makes sense all of a sudden.
Here's another one that i saw a while back.
Again, no info on the bike, just 1 pic.
IF it works .. I Wonder what Boost pressure it runs at??
Mazda Rotaries (2 strokes operating as claimed 4 strokes) run ~6 psi for Drag engines...and reputedly the All Out Mazda Factory Lemans racers were at 8 psi.
A VW Jetta is at 12 psi
Wonder how the turbo is lubricated
Scrap that question, I have just googled two stroke turbo engines to see how its done.
Pretty much on the limit of his sprokets
81Rd350lc resto 2016
81 Rd250lc resto 2017
1999 ZRX 1100
1999 ZRX 1100
- Consciousness
There was a turbo maybe banshee build back in the day that was working towards bolt on kits. Big power with reliability compared to a stroker kit. It looked very interesting. Something I wanted to look into further one day...
Id like a forced induction build, Im a big fan of it... my daily driver has both a supercharger and a turbo. If only there was a bolt on kit that would only need a bit of fettling :/
