Hose routings on '85 RZ with Mikuni carbs
Zixxer10R
#1 Post by Zixxer10R » Fri Oct 14, 2016 12:38 pm
The exploded view in the manual isn't very good at showing where the hoses connect. The "nozzles" on each carb are different as well. The two main gas feeds are obvious, as well as the two oil feeds. I think I know which ones are for the "reserve" connections, but I'm not certain. Also, there's one large hose nozzle on the right side (non enriched) carb that has me puzzled. Besides those, I don't know which connections are for the vent lines. I've had the bike running on a temporary "tank" using premix and now I need to get everything connected properly. (Note to self: next time take pictures.) Any other tips would also be appreciated.
