What PWK28 to use????
2bang
Re: What PWK28 to use????
#16 Post by 2bang » Tue Nov 08, 2016 11:00 pm
What about the Chinee knock-offs?
Like these:
https://www.aliexpress.com/item/Free-Sh ... .19.RLSPFI
https://www.aliexpress.com/item/28mm-30 ... .30.RLSPFI
I'm assuming I'll get the usual answer..... ie: junk is junk.......
But I'll ask anyway, since its mighty tempting..... a working (hopefully) set of carbs for 50 bux shipped...
IF its just a case of cheap labor coupled with crummy finish and no expensive western marketing/packaging, I could live with it... even if to have "immo" stuff on my bike...
(and upgrade later to the real thing, once all the details are worked out and got it running good).
Of course, that assumes that they DO run good.... that its JUST the details that are crap, and they're made decent....
Also that they take real Keihin jets...and that tolerances 'n such are OK, so things like jets work properly...
Greg
emartinez
#17 Post by emartinez » Tue Aug 22, 2017 11:43 am
Asking for some support I just rebuilt my 83 rz bore is 65.5 ported stock head vforce 4 spec 11 I think I am going to get pwk 28 thinking the y boot and not sure about the clutch. Does this set up sound good?
JackB
#18 Post by JackB » Wed Aug 23, 2017 8:20 am
I have a similar set up as you described and I am real happy with how my bike performs. I am using the Y boot, you will have a hard time getting it to fit the PWKs because the intake side is larger than the stock carbs but you can get it to fit.
1984 Rz350, Wicked Toomey rep pipes, Dynojet kit,Zeel unit,Toomey Y boot filter.
emartinez
#19 Post by emartinez » Wed Aug 23, 2017 12:31 pm
Thanks what size are your jets and where do you live
emartinez
#20 Post by emartinez » Wed Aug 23, 2017 6:52 pm
What is a good clutch to use that is not to stiff
#21 Post by RuZty » Thu Aug 24, 2017 6:34 am
emartinez wrote:What is a good clutch to use that is not to stiff
FZR1000 (OEM Yamaha plates) are a good upgrade, you have to toss the rubber damper rings that are with each plate in the stock clutch. You can use this with stock springs and it will work fine and feel stock on a tuned engine.
Headcoats
#22 Post by Headcoats » Sun Aug 27, 2017 8:08 am
I had some similar carbs like this from the local Kawasaki dealer and mine were for a KX 85 moto crosser
The extra vent pipes are for stopping the engine bogging when the dirt bikes are jumping
vmxwinn
#23 Post by vmxwinn » Mon Aug 28, 2017 2:36 am
I bought kx85 PWK's as well when I did it. Happy I did.
emartinez
#24 Post by emartinez » Mon Sep 11, 2017 1:21 pm
Do you think it's safe to start off with 135 mains and 45 pilots, I do have 132,138 m, 42 pilot
#25 Post by hondaror » Mon Sep 11, 2017 1:52 pm
emartinez wrote:Do you think it's safe to start off with 135 mains and 45 pilots, I do have 132,138 m, 42 pilot
You ask a jetting question, but where do you live? What elevation? What's your set-up?
Not enough info above.
emartinez
#26 Post by emartinez » Tue Sep 12, 2017 1:44 am
I live at sea level bored out 65.5 cylinders ported stock head zeel ign vforce 4 reeds with spacer 28 mm Keihin pwk uni foam filters pri mix 32/1
#27 Post by hondaror » Tue Sep 12, 2017 2:22 am
Pipes?
emartinez
#28 Post by emartinez » Tue Sep 12, 2017 2:38 am
Old spec 11
