Power valve bearings mods
p51mustang
#1 Post by p51mustang » Sun Dec 25, 2016 12:24 pm
:smt039 Hi guys well my brain has ben at work . Subject power valves and bearings has any one tried ceramic bearings in place of the bushings . Just some thing to piss around with any one see any rite ups on this ??
Thanks Larry
1978 RD 400
1979 Daytona
two-stroke-brit
Re: Power valve bearings mods
#2 Post by two-stroke-brit » Sun Dec 25, 2016 3:15 pm
there was a thread some time ago about using needle roller brgs.
i thought ceramic were more for high speed applications rather than high temp.
p51mustang
#3 Post by p51mustang » Sun Dec 25, 2016 3:19 pm
ceramic can run under the heat i do no that
1978 RD 400
1979 Daytona
p51mustang
#4 Post by p51mustang » Sun Dec 25, 2016 3:26 pm
I thinking needle bearings wood plug up under oil and carbon
1978 RD 400
1979 Daytona
(F5)
#5 Post by (F5) » Tue Dec 27, 2016 4:25 pm
My GasGas just uses normal bearings
two-stroke-brit
#6 Post by two-stroke-brit » Tue Dec 27, 2016 5:12 pm
(F5) wrote:My GasGas just uses normal bearings
when you say "normal" brgs .
what do you mean, are they ball brg or a bush type .
thanks mark
p51mustang
#7 Post by p51mustang » Tue Dec 27, 2016 7:54 pm
I was all so thinking of getting them Hard anodized that will give you a no stick suffice last longer and take the heat better :smt017
1978 RD 400
1979 Daytona
p51mustang
#8 Post by p51mustang » Tue Dec 27, 2016 8:08 pm
I have a 2 set to pis around with here as far as using ceramic bearing 1 they can take the heat I have them in my 2010 dodge challenger rt wheel hubs at 180 mph they get hot [ Performance bearing] can make any size you can come with they are made in house
1978 RD 400
1979 Daytona
(F5)
#9 Post by (F5) » Wed Dec 28, 2016 3:16 pm
Balls, inspector. (Sorry old telly add you've probably never seen)
http://www.ebay.com/itm/GAS-GAS-EC250-9 ... Sw6n5XvBEk
#10 Post by Smoker » Wed Dec 28, 2016 4:27 pm
Is there any performance gain or easier maintenance that would come with this mod?
It's not something that would be seen.
Not sure why this would be a good thing. :smt017
Bare
#11 Post by Bare » Wed Dec 28, 2016 4:37 pm
A few years back there was an Italian RZ nutter who Very skillfully fitted ball bearing races to his PV's.
Excellent craftsmanship. So it's clearly possible.
There was no evident follow up though .. as in: How did this improvement work survive carbonised goop /exhaust .
Not very well on a street use engine..I would guess.
PV's as designed by Yama are poorly thought out.
The ali shafts turning in their bushings get chewed up rather quickly. Doubly quickly when there is no maintenance .
IMO a permanent fix would be to fit steel sleeves to the PV bearing shaft bits then bore ream the Bushings to a decent fit.
Far cheaper than buying fresh Bushings which would still have a clapped out fit.
Likely a simple and durable "fix" for what Yama San bungled.
#12 Post by RuZty » Wed Dec 28, 2016 8:25 pm
...and drill a passage with a grease fitting at each bushing to allow occasional lubing without having to take the top end off.
Seals might need a rethink to not be pushed out by the grease.
evan_calgary
#13 Post by evan_calgary » Wed Dec 28, 2016 9:50 pm
As an engineering challenge sounds like fun but the barrels wear out almost as fast as the PV surfaces. ie, 30-60k KM.
I have seen a lot of barrels and few (likely none) that the PV surfaces were the limiting factor. No performance gain other than potentially opening at a more accurate rate due to lack of drag from the motor. Possibly why Yamaha didn't bother with a more intricate solution?
Steel sleeves would have to be used to protect barrels surface otherwise you still end up with steel rotating on aluminum. Would the ball bearing against the aluminum barrel wear more slowly or faster? More force on a smaller surface area.
If you want a challenge, go at it but for me you are throwing money at a problem that doesn't really exist.
p51mustang
#14 Post by p51mustang » Wed Dec 28, 2016 11:04 pm
Thanks Even just pissing around here not spending money on this i have all the parts to do this who no;s it mite just work and all i am doing is pissing around with some parts
1978 RD 400
1979 Daytona
p51mustang
#15 Post by p51mustang » Wed Dec 28, 2016 11:07 pm
evan_calgary wrote:As an engineering challenge sounds like fun but the barrels wear out almost as fast as the PV surfaces. ie, 30-60k KM.
That is some what close to what i am trying to do
1978 RD 400
1979 Daytona
