Hi smoker i don't no what gain there is I am just pissing around with this who noe's it mite just workSmoker wrote:Is there any performance gain or easier maintenance that would come with this mod?
It's not something that would be seen.
Not sure why this would be a good thing.
Power valve bearings mods
- Contact:
Re: Power valve bearings mods
1978 RD 400
1979 Daytona
1978 RD 400
1979 Daytona
- Contact:
Yes bear some thing like that its all in my head still but you are closeBare wrote:A few years back there was an Italian RZ nutter who Very skillfully fitted ball bearing races to his PV's.
Excellent craftsmanship. So it's clearly possible.
There was no evident follow up though .. as in: How did this improvement work survive carbonised goop /exhaust .
Not very well on a street use engine..I would guess.
PV's as designed by Yama are poorly thought out.
The ali shafts turning in their bushings get chewed up rather quickly. Doubly quickly when there is no maintenance .
IMO a permanent fix would be to fit steel sleeves to the PV bearing shaft bits then bore ream the Bushings to a decent fit.
Far cheaper than buying fresh Bushings which would still have a clapped out fit.
Likely a simple and durable "fix" for what Yama San bungled.
1978 RD 400
1979 Daytona
1978 RD 400
1979 Daytona
- Contact:
OOPS Bare better spellingp51mustang wrote:Yes bear some thing like that its all in my head still but you are closeBare wrote:A few years back there was an Italian RZ nutter who Very skillfully fitted ball bearing races to his PV's.
1978 RD 400
1979 Daytona
1978 RD 400
1979 Daytona
- two-stroke-brit
thats what i did , the PVs were only worn on the inside journals were the coupler fits.
so i turned them down to clean dias and sleeved them back to size.
- Contact:
I like that vary nice how much press did you use on the sleeve
1978 RD 400
1979 Daytona
1978 RD 400
1979 Daytona
- Contact:
This is a bearing from vxb bearing it is ceramic hy bird sealed only 12 $$
- kit980-2T.jpg (4.66 KiB) Viewed 2767 times
1978 RD 400
1979 Daytona
1978 RD 400
1979 Daytona
- two-stroke-brit
it was a .0005" interference fit,p51mustang wrote:I like that vary nice how much press did you use on the sleeve
i just put the valve in the freezer and warmed the sleeve with a heat gun and it fell on.
i was tempted to close the tolerance between the PV and the bushing but kept it std.
- Contact:
Nice I have a 2nd bike that i hard anodized the power valves ran it all summer i haven't taken it a part yet to see what may be going on in there in all i am just pissing around with this stuff
1978 RD 400
1979 Daytona
1978 RD 400
1979 Daytona
From Expereience: VXB bearing shop stuff is Sketchy... at best .p51mustang wrote:This is a bearing from vxb bearing it is ceramic hy bird sealed only 12 $$
Mine were so bad I had to chuck them in the trash right out of their baggie.
A Chinese 12$ Ceramic bearing...where a Decent Quality First World made one is ~100$ +.
You Really? willing to fit one.
- Contact:
Thanks Bare no I wood not use a 12$$ chine made bearing remember just pissing around here on this you never no some thing just mite work for change trust me i no what good bearing are and the cost 900 bucks for my doge challenger rt ceramic wheel bearings they are the best money can by OK back to pissing aroundBare wrote:From Expereience: VXB bearing shop stuff is Sketchy... at best .p51mustang wrote:This is a bearing from vxb bearing it is ceramic hy bird sealed only 12 $$
1978 RD 400
1979 Daytona
1978 RD 400
1979 Daytona
- motoholic71
I think it's a waste of time like a ceramic bearing to turn 1/8 at 0.0001rpm ???
More important is to keep the coupler area clean because the front wheel projects dirt there and the seals start leaking and then dirt gets in there... so a protection might be much more effective. Also the loose clearance is needed because the valves get really hot. They could have had water circulating under the exhaust port.
I made a simple flat thin steel shield shaped with tin snips retained by the inner header bolts.
- motoholic71
- Contact:
Thanks Motoholic 71 that about sums it up
1978 RD 400
1979 Daytona
1978 RD 400
1979 Daytona
