Adjusting the idle RPM on RZ350
Can the idle RPM adjusting screw be accessed without removing the gas tank? What a pisser!
- Evans Ward
Re: Adjusting the idle RPM on RZ350
Yes, it can be done. I adjust idle with bike on centerstand using a long flathead screwdriver to move the wheel mechanism. No need to remove fuel tank.
I've got a 12" long Phillips head screw driver that I can stick in with the seat removed and the rear of the tank elevated, but I'm going to come up with a flexible cable attached to the screw(or another screw) like most bikes have. Thanks for the response.
Ditto on the long screwdriver, just make sure the idle screw is well lubed. A couple I have had were so corroded that they wouldn't turn.
84 RZ350 Allspeed GP replica pipes, milled head, PWK 28mm Keihins, Y air boot/ k&n filter, VForce4’s, Zeel, Dynatec ignition coil,R6 calipers, Ohlins, sonic springs 80wt fork springs, FZ1 master cylinder.
