Where to find OEM Piston Rings?!?!
Putting an RZ350 engine back together and I need piston rings for OEM pistons ..... are they really $80/pair and only to be shipped from Japan or some guy in Chile? Am I missing an easier option ... ?
Re: Where to find OEM Piston Rings?!?!
Here's a set of rings for a standard (64 mm) piston.
They are listed a Banshee rings, but they are the same as the RZ350.
http://www.ebay.com/itm/NOS-Yamaha-YFZ3 ... 2417217334" onclick="window.open(this.href);return false;
The same seller also has 3 sets of Standard rings for the 86+ RZ350,
Part Number 1UA-11610-00-00.
I know the seller and he has them in stock, but just hasn't got around to listing them on Ebay.
He also has 1 set of 1st over (64.25mm) Banshee rings in stock but not listed.
That Universal Cycle's ebay ID?
The only parts you can't buy for the RZ350 engine, OEM, are Pistons.
Oh no! Rory, are you telling me I sold the rarest RZ part at a discount! Such a shame :P
Recent development? I bought some 2 years ago, would have thought with Banshees being made up to 2005 or so they would have pistons covered for the rest of my riding life.hondaror wrote:The only parts you can't buy for the RZ350 engine, OEM, are Pistons.
- Evans Ward
For the US spec bikes, the OEM Pistons and rings are out there but you have to look and be prepared to pay up.
Yama Only supplied 2 oversizes in Pistons and Rings.
One can fit Banshee intended ones though.
Important to note that OEM RZ ring sets included the Wiggly expander ring.
V clever to fit one. As in it's important.. there are no 'extra' parts, at least in a street used engine.
Preferably oem though as the Riken ones are Sketchy. Oem ones don't normally break. Riken ones.. welll feeling lucky?
That spring ring served to keep the Piston centred in the bore .. reducing, even possibly preventing Piston slap noises.
It's easy to identify an engine assembled without the wiggly spring ring.. It has audible piston slap at idle V much like a still cold Wiseco fitted engine does.
That is what my friend has told me. Yamaha Canada Service Manager.RuZty wrote:Recent development? I bought some 2 years ago, would have thought with Banshees being made up to 2005 or so they would have pistons covered for the rest of my riding life.hondaror wrote:The only parts you can't buy for the RZ350 engine, OEM, are Pistons.
Welll.. consider the source..Yama Canada has say what 3 dealers left alive?
Parts Are available Here:
http://www.procaliber.com/oemparts/a/ya ... aft-piston" onclick="window.open(this.href);return false;
Curios to know weather these oem rings will fit the oem 4lo pistons
Rob
Rob
Yes.. but it's rare / unlikely that one can replace rings without requiring fresh pistons. Bore clearances are Critical.
thanks for that Bare . Just had my barrels and head done by Scott Clough all they needed was a light hone but also had the squish and oring done at the same time . He said the barrels look fresh at the the standard 64mm bore and sugested if the pistons looked good to carry on using them so i cleaned them up and they and the pins look in good condition with no play in the new bearings but the fellow who had the bike before me replaced them with riken rings so i thought i would go back to oem .I think i will try a set.
