Chamber silencers
Chamber silencers
Anybody know the outside diameter of most of the aluminum style slip on bolt on silencers. Wanting to tuck the chambers in tight and have had clearance problems in the past
Re: Chamber silencers
ID or OD?
ID is usually around 22-25mm, OD is 65ish.
Are the ones like Toomey and Kenny use really that big? I made some from 2" o.d. Aluminum tubing and I like the look 2.25 might work better for noise?
I don't know and prob wouldn't look to big but I checked out some 2.5 and it just looked way to big
Compared to the pictures of the ones I'm seeing
Well you are provided exactly zero info. on what you are looking at so as far as we know you are looking at a piece of spaghetti attached to a cheerio....if that is the case then yes, 2.4" tubing will look large compared to the spaghetti and the cheerio.
If you are looking for approx. diameter of aftermarket silencers then 2.5" is a good approx. The cheepy Chinese ones are 2.4". I had some old school stubby alum and they are around the same as are the stock RS250 carbon/kevlar ones.
Tyga still sells new ones as do other retailers you could ask for sizing...
My TZMikes silencers are 2.5 inches by 10 inches long, and look great.
I have a pair from Nigel Kimber (NKRacing) and they a 2 3/8" OD, and are the same diameter as the flange on TSA pipes.
Sounds like mine are pretty small looking at the toomeys kennys and others I didnt think they were that big. Thanks for the info guys hops mine don't turn out to loud
