RD/LC Primary gearing.
Airmun
#1 Post by Airmun » Mon Feb 13, 2017 6:42 pm
Can anyone tell me what differences in primary gearing (If any) there are in the various models of RD/LC.
Most crankshaft gears are 23T. Are there any variations between models and capacity (As per TZ)?
Any help would be appreciated.
EE
Re: RD/LC Primary gearing.
#2 Post by EE » Mon Feb 13, 2017 7:34 pm
The aircooled RD250 and RD350 had different primary gear ratios. And just like you mentioned the TZ250 and 350 had different primary ratio's (though different than the RD250 and 350), but by the RD250/350LC Yamaha had settled on one ratio and used the same ratio in the RZ250/350 and later in the Banshees. (They used the same ratio in the RD400's as well). Ed
http://www.erlenbachracing.co" onclick="window.open(this.href);return false;
Airmun
#3 Post by Airmun » Mon Feb 13, 2017 10:04 pm
What were the earlier crankshaft gears number of teeth?
EE
#4 Post by EE » Tue Feb 14, 2017 12:14 am
Alright had to dig through the old notes a bit but:
Aircooled RD250 68/21 3.238
Aircooled Rd350/400/RD250LC/RD350LC/RZ250/RZ350/Banshee 66/23 2.869
Early TZ250's 77/23 3.35 (Dry clutch/straight cut)
TZ350's 74/25 2.96 (Dry clutch/straight cut)
Airmun
#5 Post by Airmun » Tue Feb 14, 2017 12:29 am
Many Thanks.
Dave1w
#6 Post by Dave1w » Tue Feb 14, 2017 4:52 pm
I think the only thing to add (remember) is that they went to matched gears later on for the YPVS (so I seem to remember )
