Couple ?? About weight
What's do some of the popular pipes weigh per pipe with silencers?? Spec 2. DG kennys toomey etc.
Also what about the weight of an old rd350 or rz350 all stock except for aftermarket pipes and a full tank of gas. ??
- two-stroke-brit
Re: Couple ?? About weight
i weighed 1 spec11 pipe and it was 5lbs.
mark
mark
I just weighed these.
Right Side Stock Canadian/European style Exhaust with baffle. 10.35 LBS
Right side Toomey with clamp and one spring and silencer. 5.77 LBS
- Questo vecchio rz
A stock RZ weighs around 375 lbs with fuel. Thats a US spec machine w catalytic converters in the pipes, I've had Canadien spec pipes and they feel almost as heavy but probably 5 lbs lighter.
My batteties are low in my scale, but show a set of Lomas GP pipes in stainless to weigh 5.5 lbs for the entire set, that both pipes ( no silencers) there carbon I'm guessing them at about 2.5 lbs. JL pipes in stainless use a thin ga. metal much lighter than mild steel pipes Ive had.
Thanks much. Trying to compare and watch weight on my project best I can. Pretty hard to do on a budget. Really trying for no more than 375 lbs without fuel. At this point can only hope
- Questo vecchio rz
Is this your 4 cylinder project you are refering too?4cyl h2 wrote:Thanks much. Trying to compare and watch weight on my project best I can. Pretty hard to do on a budget. Really trying for no more than 375 lbs without fuel. At this point can only hope
Either way..it is a challenge on a budget.
All I can ad is ..strip as much necessary brackets, components, wiring as possible within what works for you.
Use as much alum & carbon fiber, fiberglass as possible. Trim bodywork, delete R fenders shorten fronts, minimal battery, led headlight if at all etc.. Its all a sacrifice..you have to decide how much.
Search any vintage sites for old school magnesium or wire wheels and components..often old stashes go pretty reasonable. I prefer cast wheel looks over spoked but RD350 etc.. spokes are ofen FAR lighter than period model mag look casts. . If this is not a racer..you can delete 1 front rotor, utilize a small scooter rotor@ rear etc..
I think your goal of 375lbs is pretty realistic even w a double widened case as long as you follow some basics.
If this is just a RD or RZ then you can be down to a fighting weight of 345 lbs in a afternoon..easy.
You are just a compulsive liar that likes to pollute the rz forum and others with your unfounded guff. Look forward to your response............how much do they really weigh?Questo vecchio rz wrote:
My batteties are low in my scale, but show a set of Lomas GP pipes in stainless to weigh 5.5 lbs for the entire set, that both pipes ( no silencers) .
SLINGER
Nope. Those pipes are close to 8 lbs. with no silencers.Questo vecchio rz wrote:My batteties are low in my scale, but show a set of Lomas GP pipes in stainless to weigh 5.5 lbs for the entire set, that both pipes ( no silencers) there carbon I'm guessing them at about 2.5 lbs. JL pipes in stainless use a thin ga. metal much lighter than mild steel pipes Ive had.
Yes it's my 4cyl project thanks for the tips
If you do have some extra bucks, titanium fasteners can shed some weight, but the $$ add up quick.
You can also skeletonize or hollow out some parts here and there.
- Questo vecchio rz
slinger wrote:You are just a compulsive liar that likes to pollute the rz forum and others with your unfounded guff. Look forward to your response............how much do they really weigh?Questo vecchio rz wrote:
SLINGER
Slinger..your such a pissed off dude w a fucked up ego problem its quite simply pathetic that you pick petty issues such as this, especially when "Lomas" or "Toomey" or Another Tuner are mentioned you feel the need to attempt to smear people whom are just here as a fun hobby..your such a creep. Like I really have an adgenda to fabricate and lie...get a life. If anyone disrupts a forum...its you! Go look in the mirror or read your arrogant cocky posts. I really look down on indaviduals such as yourself whom try to make themselves look better or knowledgable at the expense of others, your often of poor character.
For anyone else..my entire system weighs in at less than 10 lbs. But I'll give the benefit of the doubt & say 10. This is from 2 seperate weighings on two diffrent brand new scales, 7 or so years apart. The old digital scale today...was (obviouslly as implied by the statement "weak batteries") likley off a little due to orig batteries and years of 120° heat. So I bought a new one that is perfectly fine for this application. Theres no need for anything fancy its horseshoes & hand grenades...close enough. Pictures show the reality.
Below is what the facts are. I weighed each pc 3 times
Left pipe w spigot 3.5 lbs. Right pipe w spigot 3.0 lbs. Silencers 2.0 lbs Thats 9.5 lbs..2 scales..yes basic scales not pharmaceutical or merchant grade down to the grams.
Its accurate enough, it weighed & confirmed everything I put on it, 2 lb 3lb. 5 lb 10 lb.weights all read correct. CLOSE ENOUGH..thats what my pipe set weighs. Others..who knows results may vary or be marginally more accurate..I could really care less,
& Slinger..So BFD.. it was off 1.0 lbs..there still dammned light. Read it & weep BEOTCH...Your still a forum troll, a shithead and have a huge chip on your shoulder, just the fact you came on here and felt possessed to post what you did, just confirms what a idiot you are..really calling one a blatant liar over 1.0-1.5 lbs on a stated questionable scale. Once again sticking your nose into a perfectly nice thread on a discussion about ballpark weight...Moron. Your such a fucking idiot Im so glad I never did any buisness with you..so glad! .
SCALE READS 3 LBS CORRECTLY.
LEFT PIPE: 3.5 lbs.
RIGHT PIPE: 3.0 lbs
SILENCERS:3 lbs
MY NOTES FROM 7 YEARS AGO: about 10 lbs
AND FINALLY SLINGER THIS IS FOR YOU:
Last edited by Questo vecchio rz on Mon Feb 20, 2017 7:24 am, edited 5 times in total.
When I first read this, I thought wow, your weights are high. 4 cylinders, that changes things quite a bit. I had my old LC under 300 lbs. They were 315 stock, dry.
You don't say whether you are running premix or injector. Power valve or not. Are you racing the bike or street?
Picture this for the track: No power valve=no servo, no servo brain, no servo cables. Premix=No injector oil tank, no oil pump. No tail lights, headlight, signals, wiring for lighting, seat, seat locks, tabs in the rear end, cut off excess rear frame, run 2 layer glass seat and fairing. Cut stand mounts off. Remove kick start and cluster and have hole welded up. remove flasher unit, and unneeded relays. On the LC, no battery, total loss is fine. Convert to 520 chain and aluminum rear sprocket.
Stock tire sizes, as they are lighter. Drill holes on the perimeter of all washers. Remove air box and run open carbs. Remove rear foot pegs and cut mounts off. Pipes. Remove speedo, speedo drive gear and cable. Remove ignition switch and key. It all adds up. You're almost heading into 250 GP weights. Old TZs were around 220 lbs dry.
Man Questo vecchio rz you really have the hate thing going on , let it all out dude your make yourself ill with all the hate in ya
Premix rd and r5 cylinders hopefully mostly a powerful(after lots of refinement I'm sure) street fun bike
- T.RexRacing
Just out of curiosity this old rz where did you find a 3 pound butt plug with an o-ring seal to minimize leakage?
Salvador Dali
Salvador Dali
