Exhaust templates
Exhaust templates
Does anyone have templates to a good exhaust to a stock rd350 ypvs?
Re: Exhaust templates
Templates? Do you mean for pipe design? If so there are plenty of programs out there that can assist. Fairly easy to learn if you are planning on going to all the trouble of welding your own. Suggest starting there. I have not personally seen plans floating around and they will depend on what you are looking for in a pipe.
yes and I need info on this.
Exhaust open period in degree
Main transfer open period in degree
Secondary transfer open period in degree
Rear boost port open period in degree.
I guess that may turn out helpful:
http://l3s9113.zeus09.de/RD350/Auspuffb ... glisch.pdf" onclick="window.open(this.href);return false;
This one wasn't too bad:
http://1.1.1.4/bmi/forum.rd350lc.de/fil ... in_149.png" onclick="window.open(this.href);return false;
It was to great help but I still need those degrees to get the correct sizes of the expansion chamber. I have a program but don't have the knowledge to get the correct degrees.
If you have the ability, stop sweating it and dive in. Practice goes a long way. All the great pipe makers learn from trial and error, even with good specs. Find something, and go for it.
