Quick question... what side goes in?
Water pump bearing RZ350
- motosapien
Re: Water pump bearing RZ350
Usually you put the stamped side in, so nothing gets scraped off.
- motosapien
The plastic faces the water sidehondaror wrote:Usually you put the stamped side in, so nothing gets scraped off.
2>4
Did not know it has plastic insert or that the two sides were different. Only one side in the pic.
Bearings with sizes stamped or printed on one side should always be protected from external buggering, as should shims. Keep the stamped side off of lobes.
