PWK vacuum take off for tank tap.
L.B
#1 Post by L.B » Fri Mar 17, 2017 8:30 pm
Has anyone ever used this spigot to take a vacuum off for tank tap? Id like to keep the reserve function.
Its in the same place as the mikuni carbs & seems like it can be drilled through with no issues. Just like to know if anyone else has tried this.
Bare
Re: PWK vacuum take off for tank tap.
#2 Post by Bare » Sat Mar 18, 2017 6:28 pm
It IS possible (practical even) to fit a T to one of the oil fittings and use the resulting 'extra' connection for a Vac connection.
Yesss It's been done before and Yess it works 'fine'.
gpaddict
#3 Post by gpaddict » Fri Mar 24, 2017 7:37 pm
T in your oil line for vacuum??????
tuned to Paris Hilton specs............rich and retarded!
Bare
#4 Post by Bare » Sun Mar 26, 2017 11:45 pm
Was it mistyped!
Buy a cheap plastic T fitting (windshield washer type will do) .
Simply insert it into the oil feed line close to the carb.
2 mins later and you will know if it works.. Or not :smt002
JonW
#5 Post by JonW » Mon Mar 27, 2017 8:37 am
It works, Ive done it before too.
L.B
#6 Post by L.B » Mon Mar 27, 2017 10:17 am
Thanks for the reply bare but wont risk a new build engine worth nearly 3k thanks. Hence why i asked if anyone has drilled a pwk in that spot for vacuum.
One also has to wonder why Yamaha didnt use this method either?
Have emailed Keihin for a def answer.
justind97
#7 Post by justind97 » Mon Mar 27, 2017 5:07 pm
What about. Small barb in the reed cage area? We did that for karts
tacky1
#8 Post by tacky1 » Tue Mar 28, 2017 12:21 am
This is where I put it on both my 350's, One is running PWK28s and the other is running 34mm flatslides, Works perfect.
I used to run a T off the oil line with the 34,s, I swapped it over, made me fell better.. :)
yamasukiman
#9 Post by yamasukiman » Tue Mar 28, 2017 11:25 pm
Is there not a mod where you can turn the tap into a "on-off" manual tap and do away with the vacuum port?
I'm sure I've seen it on one of the forums.
JonW
#10 Post by JonW » Wed Mar 29, 2017 12:38 am
yes there was a post on it here somewhere, you mod the rubber or plastic bit in the tap to bridge the holes.
vmxwinn
#11 Post by vmxwinn » Wed Mar 29, 2017 2:48 am
I did the exact same as tacky1. It is so easy to just drill a hole in the cross over tube and tap a brass npt/barb in. Not even worth messing with the petcock. Ten minute job at best
Bare
#12 Post by Bare » Fri Apr 21, 2017 12:34 am
Silly answer being : if you can't sus it out.. you don't get to ride :-)
L.B
#13 Post by L.B » Fri Apr 21, 2017 9:57 pm
Well i sorted it out,been for a ride & works fine,simple fix really. Pics soon.
L.B
#14 Post by L.B » Sat Apr 22, 2017 3:25 am
This mod isn't for everyone,i mainly wanted to retain stock look as much as possible including hoses etc.
So...here we go drilling into brand new 28mm pwk's.
Start with a 3mm drill bit & drill through this spigot/nipple to the intake tube.
Then take a 4mm x .7 plug tap & tap this hole approx 5mm in,drilling through for the vacuum cross drills into this circuit. Its not used as it is an optional bowl vent. There are 2 vent holes & the other side is used so all good.
Then take your 4mm grub screw that has a slight coating of fuel proof thread lock & tighten into place.
Ultrasonic clean carb & blow it out to clear any chips etc from drilling & tapping & you're done. Make sure your thread locker is fuel proof.
Oh,then ride & enjoy.
JonW
#15 Post by JonW » Sat Apr 22, 2017 3:54 am
Great work mate!
