PWK vacuum take off for tank tap.
Re: PWK vacuum take off for tank tap.
It IS possible (practical even) to fit a T to one of the oil fittings and use the resulting 'extra' connection for a Vac connection.
Yesss It's been done before and Yess it works 'fine'.
T in your oil line for vacuum??????
Was it mistyped!
Buy a cheap plastic T fitting (windshield washer type will do) .
Simply insert it into the oil feed line close to the carb.
2 mins later and you will know if it works.. Or not
It works, Ive done it before too.
Thanks for the reply bare but wont risk a new build engine worth nearly 3k thanks. Hence why i asked if anyone has drilled a pwk in that spot for vacuum.
One also has to wonder why Yamaha didnt use this method either?
Have emailed Keihin for a def answer.
What about. Small barb in the reed cage area? We did that for karts
This is where I put it on both my 350's, One is running PWK28s and the other is running 34mm flatslides, Works perfect.
I used to run a T off the oil line with the 34,s, I swapped it over, made me fell better.. :)
Is there not a mod where you can turn the tap into a "on-off" manual tap and do away with the vacuum port?
I'm sure I've seen it on one of the forums.
yes there was a post on it here somewhere, you mod the rubber or plastic bit in the tap to bridge the holes.
I did the exact same as tacky1. It is so easy to just drill a hole in the cross over tube and tap a brass npt/barb in. Not even worth messing with the petcock. Ten minute job at best
Silly answer being : if you can't sus it out.. you don't get to ride
Well i sorted it out,been for a ride & works fine,simple fix really. Pics soon.
This mod isn't for everyone,i mainly wanted to retain stock look as much as possible including hoses etc.
So...here we go drilling into brand new 28mm pwk's.
Start with a 3mm drill bit & drill through this spigot/nipple to the intake tube.
Then take a 4mm x .7 plug tap & tap this hole approx 5mm in,drilling through for the vacuum cross drills into this circuit. Its not used as it is an optional bowl vent. There are 2 vent holes & the other side is used so all good.
Then take your 4mm grub screw that has a slight coating of fuel proof thread lock & tighten into place.
Ultrasonic clean carb & blow it out to clear any chips etc from drilling & tapping & you're done. Make sure your thread locker is fuel proof.
Oh,then ride & enjoy.
Great work mate!
