power valve
Russ Coyote
power valve
#1 Post by Russ Coyote » Mon Mar 20, 2017 6:12 pm
I have coolant leaking from cap on left side power valve. Can the seals be replaced w/o
removing the top end?
Thanks to all,,
justind97
Re: power valve
#2 Post by justind97 » Mon Mar 20, 2017 6:42 pm
You have a much more serious issue if there's rad fluid coming out the powervalve. The two are not connected. I think that cylinder might have a crack where it doesn't belong....
Re: power valve
#3 Post by JonW » Mon Mar 20, 2017 7:06 pm
what Justin said. you need to investigate this ASAP, coolant should not be near the PVs.
Re: power valve
#4 Post by MK » Tue Mar 21, 2017 8:31 am
Sounds more like a head gasket issue where the water finds its way down to the valves.
justind97
Re: power valve
#5 Post by justind97 » Tue Mar 21, 2017 9:17 am
MK wrote:Sounds more like a head gasket issue where the water finds its way down to the valves.
I was originally thinking this too. He'll need to put a paper towel on the cylinder and see if that's the case..
Re: power valve
#6 Post by hondaror » Fri May 19, 2017 5:59 pm
I like the way Martin thinks.
