1990 F2 Wont Rev out past 6k
Hello
I am rather new to the forum , posted a few times since..
I picked up a 1990 F2 from Canada.
It showed up this past week, replaced the battery on Saturday and took it for a short shakedown run to see if the bike had any major issues...
Everything worked 100%
Move on to today Sunday
I take it out for a spin and about a mile from my home it starts bogging around 6k, no power at all.
I pulled over and it seems to rev fine with the clutch in and idles fine.
Once you apply a load to it , it wont go past 6k.
First thing I thought was plugs, so I added a new set of plugs.
Took it for a ride and the same issue continued.
Gas is fresh 89 Octane Recreational Gas 100% Gasloline.
Any ideas ?
Im thinking of cleaning the carbs to start with, is there a write up anywhere on how to remove them.
I am pretty familiar with 2 strokes from my motocross days, but nothing that was a twin.
Thanks in advance
Todd
Any ideas ?
Thanks in advance
Todd
Re: 1990 F2 Wont Rev out past 6k
It could be rich on the main jet. Take a look at the plugs right after Biggs down. Does it work better when the weather is cold. Today in the afternoon was quite warm in Detroit.
Hi ,make sure the power valves are set correctly. as in opening as the revs go up .
Todd,
The twins will be pretty much the same deal as your 2-stroke moto bike. The carbs are just a much more painful experience to pull.
Checking the PVs is a good test. You should be able to see the cables moving on the left hand side of the motor.
From your description it sounds like the bike was working properly for the first mile then the issue arose? I think this is important to confirm.
Sounds like fuel starvation. Has the tank been sealed? Blocked vent?
Inline aftermarket Fuel filters rarely sit nicely and kink the fuel lines.
But always clean carbs on an old bike you just bought. Check vacuum hose from carb to petrol tap and that it works.
The bike ran fine for the hour or so I rode it on Saturday afternoon. On Sunday it only ran well for about a mile then this issue arose.evan_calgary wrote:Todd,
Pulled Tank
Pulled Carbs
Tested the diaphram on the petcock valve , we are flowing fine in all positions.
The bike had an inline filter on it and I did not see anything inside the filter , I will replace with a new one
Seems to be a very slight bit of rust in tank , I drained it removed the Petcock and heard little bits of something rolling around in the tank.
I made a plate for the petcock and used a gallon of EvapoRust in the tank and every single angle i could think of , this should cure any rust issues that were present.
Sonic Cleaned the carbs
I could not find any smoking gun in the carbs but they were in need of a cleaning , also replaced the needle and seat as well as float bowl gaskets while i was in there .
Also removed the reeds to inspect for any abnormal wear , nothing present .
I also took the time to do a compression test that showed about 135 on each cylinder.
I will put the bike back together tomorrow and try it again.
Fingers crossed...
Pulled Carbs
Fingers crossed...
Clean the system and get rid of the inline filter more trouble than they are worth
75 RD350
83 RZ350
87 RZ350
03 KX250
78 DT175
83 RZ350
87 RZ350
03 KX250
78 DT175
That would be my first thought! Especially with rust particles found in the tank.(F5) wrote:Sounds like fuel starvation. Has the tank been sealed? Blocked vent?
90 RZ Race Bike
86 RZ daily driver
85 RZ low milage
86 RZ daily driver
85 RZ low milage
Got it all back together , new fuel line and vent lines.
I forgot which vent line from the carb provides vacuum for the diaphragm on the petcock .
Thanks again
Thanks again
Why are they trouble ?Morty wrote:Clean the system and get rid of the inline filter more trouble than they are worth
Took the bike out for a ride today ...
Same issue as originally stated .....
So now that we know that its not a fuel issue.
Where to next ? Exhaust ? Plugged up silencers ? Dirty Power Valves ?
Electrical ?
Thanks in advance
Electrical ?
Thanks in advance
[youtube][/youtube]
Because they restrict flow, there is already a screen on the petcockSitnlow4life wrote:Why are they trouble ?Morty wrote:Clean the system and get rid of the inline filter more trouble than they are worth
75 RD350
83 RZ350
87 RZ350
03 KX250
78 DT175
83 RZ350
87 RZ350
03 KX250
78 DT175
Interesting .....Morty wrote:[youtube][/youtube]Because they restrict flow, there is already a screen on the petcockSitnlow4life wrote:Why are they trouble ?Morty wrote:Clean the system and get rid of the inline filter more trouble than they are worth
Think that might be my issue ?
might very well be if they are choked up.Sitnlow4life wrote: Where to next ? Exhaust ?
if it runs, you can race it !
