O-Rings for Toomeys
TCRZ88
O-Rings for Toomeys
#1 Post by TCRZ88 » Tue Apr 18, 2017 4:56 pm
Anyone know the size of o-ring for Toomey pipes? Anyone know if they make silicon ones and where to get them? Just read an earlier post where I hear they are heavy junk. [DISAPPOINTED BUT RELIEVED FACE]
RZResurection
Re: O-Rings for Toomeys
#2 Post by RZResurection » Tue Apr 18, 2017 6:39 pm
Not sure on the size. Could you remove a pipe and measure one up? They are most likely a standard imperial ring.
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Milled Head (0.020")
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
TCRZ88
#3 Post by TCRZ88 » Tue Apr 18, 2017 7:11 pm
I can. I just wondered before I pull the pipes off and can't ride if someone would know the dimensions. The bigger question is are they available in silicon?
Evans Ward
#4 Post by Evans Ward » Tue Apr 18, 2017 7:15 pm
I have some new ones out in the shop I can measure for you.
TCRZ88
#5 Post by TCRZ88 » Tue Apr 18, 2017 7:30 pm
That would be good if you could.
pushstartrearset
#6 Post by pushstartrearset » Wed Apr 19, 2017 10:58 am
The o-ring I measured is the stinger tip (end cap) o-ring at the very end (snap ring holds the aluminum tip in place @ exhaust exit. My measurements: 1.958" ID X 2.280" OD X 0.135" Width. The closest I could find was #226 Silicone O-ring @ McMaster-Carr for $9.64 (10 pack). Might be worth a try to see if they fit. I remember finding snap rings at Fastenal for the J&R pipes i have o n the RD350 A/C. I had a machinist machine down some toomey end caps to fit the slender ends. Works like a charm, also used toomey perforated cores too. Problem solved!
L I N K: --------> https://www.mcmaster.com/#1283n98/=179k1fj
TCRZ88
#7 Post by TCRZ88 » Wed Apr 19, 2017 11:45 am
pushstartrearset wrote:The o-ring I measured is the stinger tip (end cap) o-ring at the very end (snap ring holds the aluminum tip in place @ exhaust exit. My measurements: 1.958" ID X 2.280" OD X 0.135" Width. The closest I could find was #226 Silicone O-ring @ McMaster-Carr for $9.64 (10 pack). Might be worth a try to see if they fit. I remember finding snap rings at Fastenal for the J&R pipes i have o n the RD350 A/C. I had a machinist machine down some toomey end caps to fit the slender ends. Works like a charm, also used toomey perforated cores too. Problem solved!
Are you talking about the one at the front of the silencer? Just to clarify there is an o-ring on the inside of the pipes at the engine flange end as well.
Evans Ward
#8 Post by Evans Ward » Wed Apr 19, 2017 12:48 pm
TCRZ88 wrote:That would be good if you could.
I looked but could not find mine- sorry.
TCRZ88
#9 Post by TCRZ88 » Wed Apr 19, 2017 1:26 pm
Guess I'm taking em off and measuring[emoji14]
TCRZ88
#10 Post by TCRZ88 » Wed Apr 19, 2017 1:31 pm
Those look like the right ones
pushstartrearset
#11 Post by pushstartrearset » Wed Apr 19, 2017 2:05 pm
Not at the flange where it (header) mounts to the cylinder or (pictured) where it mounts to the end of the expansion chamber @ exhaust end (that's a banshee T5 can i think).... see image (below).
CORRECTION: Looks like both silencers pictured are T-5 toomeys. You can tell by the "hangars" welded near the center and top of silencer can for banshees. I would think the o-ring would be shared or the same. Someone correct me if I am wrong.
TCRZ88
#12 Post by TCRZ88 » Wed Apr 19, 2017 4:24 pm
I thought that one is the one you were referring to. I need the dimension for the o-ring at the cylinder end where the header mounts over the flange. Would you know that dimension? Do you have o-ringed headers as well?
75RD350rider
#13 Post by 75RD350rider » Wed Apr 19, 2017 7:23 pm
Toomey has them in stock. I ordered a set and had them in 4 days.
Tim Steele in Front Royal, VA
