Advice - carbs & two into one filter
pxgallagher
#1 Post by pxgallagher » Sun Apr 30, 2017 10:51 am
Picked up my second RZ350, the first fairly stock w/ Toomey's .... but the second was just a bargain find on an RZ that was on the track. A ton of fun (for a few minutes) around town. The carb's (larger Mikunis) seemed to be jetted for full out open throttle (which may make sense on a track bike); seemingly quite rich in the mid range ... and useless below 6K RPM. Above 6K it is a monster.
The 2 into one air filter connect to the carbs (right)...but they actually connect to an adapter on the carb. Those adapters are black and upon inspection, some of the "black" is flaking off on the inside ... so likely clogging up a carb, etc. The
Questions:
1) What is the adapter as I would love to just buy a new set?
2) If a new set cannot be found, should I just clean them to their chrome state? That is, get rid of the "black"?
Thoughts? And yes, I've read the numerous comments on original airbox's vs. two into ones, etc. but at this point my time and money are going into my other RZ so not looking to change a lot on this one (at this time).
Thanks,
Patrick
Re: Advice - carbs & two into one filter
#2 Post by RuZty » Sun Apr 30, 2017 8:33 pm
On stock Mikunis the 2 to 1 clamps right on the carbs, if your bike is running larger carbs the PO must have made something up to make it fit.
Evans Ward
#3 Post by Evans Ward » Sun Apr 30, 2017 9:08 pm
You can purchase the 2-1 "Y" boot adapter from Toomey off their web site.
Can you post a picture of your set up?
#4 Post by JonW » Sun Apr 30, 2017 11:04 pm
I thought the Y boot was standard fit on another model, maybe an AC?
yamasukiman
#5 Post by yamasukiman » Mon May 01, 2017 8:23 pm
On stock size carbs, Y boot off aircooled Yamaha rd350 fit.
You can use the same tall K+N type filter(as they do in the aircooled) if you run a custom battery box.
I also didn't have an oil pump so that oil reservoir wasn't there either.
It makes jetting changes very simple!
