Big Bores, how big can you go before........
Lopper
#1 Post by Lopper » Sat Jun 24, 2017 4:38 am
the vibration is unbearable? (assuming bar weights, aftermarket engine mounts etc are used)
Lopper
Re: Big Bores, how big can you go before........
#2 Post by Lopper » Wed Jun 28, 2017 8:47 am
bump
evan_calgary
#3 Post by evan_calgary » Wed Jun 28, 2017 1:03 pm
Being it is a twin you are at least in better shape than a big single but over 500 you will start to see some strong vibration. This is likely a question for the Banshee HQ guys.
Once you get that big you end up with a diesel rather than a peaky motor as well which is one of the biggest turn offs for me.
Lopper
#4 Post by Lopper » Thu Jun 29, 2017 5:10 am
evan_calgary wrote:Being it is a twin you are at least in better shape than a big single but over 500 you will start to see some strong vibration. This is likely a question for the Banshee HQ guys.
I thought those cpi dm cylinders were quite peaky?
slinger
#5 Post by slinger » Thu Jun 29, 2017 6:52 pm
The only real answer is how deep are your pockets?
evan_calgary
#6 Post by evan_calgary » Fri Jun 30, 2017 12:40 pm
The only reference I have seen about the >500cc builds is they have piles and piles of torque and are called 'diesels'. Have not ridden or built but you were obviously hunting for some reply so relayed over what I had heard. Again, banshee HQ has piles and piles of info. and builds...
Zombie
#7 Post by Zombie » Fri Aug 04, 2017 11:53 am
Depends on your definition of "unbearable".
And a properly balanced crank can take away the shakes.
