Engine RPM at 60 MPH
350YPVS
#1 Post by 350YPVS » Sat Jul 29, 2017 8:34 pm
Hi all,
On my conversion I'm trying to get my gearing / sprockets sorted out (as the bike revs to high right now due to the 17 inch tire). Could someone tell me what the stock RPM is at 60 MPH?
Thx.
J
RZed
Re: Engine RPM at 60 MPH
#2 Post by RZed » Sat Jul 29, 2017 9:44 pm
I'm running a 17 tooth front and a 39 tooth rear on my hybrid with 17" wheels. At 60 mph I'm turning about 5200 rpm.
Hope that helps.
Charlie
99 R1 USD front end
Tarrozi Hi-rise clipons
VJ23 swingarm
JL GP stainless pipes
2018 XSR 900
350YPVS
#3 Post by 350YPVS » Sun Jul 30, 2017 8:35 am
Yes it does! Thx!
J
#4 Post by Smoker » Sun Jul 30, 2017 12:08 pm
http://www.gearingcommander.com/" onclick="window.open(this.href);return false;
RZed
#5 Post by RZed » Sun Jul 30, 2017 5:16 pm
Just got back from a ride and at 60 mph I'm actually turning 4800 rpm.
Charlie
99 R1 USD front end
VJ23 swingarm
2018 XSR 900
Hooligan
#6 Post by Hooligan » Sun Jul 30, 2017 8:27 pm
You are geared quite low. My LC turns around 6000 rpm at 60 mph (100 km/hr).
RZed
#7 Post by RZed » Sun Jul 30, 2017 11:29 pm
Hooligan wrote:You are geared quite low. My LC turns around 6000 rpm at 60 mph (100 km/hr).
Yeah, I probably am. I might go up a couple of teeth on the rear the next I do chain and sprockets. But I mainly ride higher speed back roads and the gearing works well for me.
Charlie
99 R1 USD front end
VJ23 swingarm
2018 XSR 900
#8 Post by hondaror » Sat Aug 05, 2017 8:07 pm
I prefer stock gearing, as I run non o ring chains. O ring chains rob power on small bikes. Going smaller on the front sprocket wears out the chain faster. I would shoot for stock ratios on the tach by altering the rear sprocket. That's my $0.02.
Bare
#9 Post by Bare » Sun Aug 13, 2017 9:10 pm
Small aside: Neither the Speedometer Nor the Tachometers have history of being accurate... far from it :-)
Even when Brand new. Speeds you can verify with a GPS.
Rpms with a proven tach device.
Best know what yer dealing with... before fooling with the bits.
evansje1
#10 Post by evansje1 » Fri Aug 18, 2017 5:44 am
Bare wrote:Small aside: Neither the Speedometer Nor the Tachometers have history of being accurate... far from it :-)
Typically 10% high. 60mph in sixth gear should be 5k rpms. My analog tach shows 5500 at 60mph while the Vapor I have displays 5k at 60. Tthe 350/400 RD's are also geared to turn 5k at 60mph.
1973 RD350
2014 Suzuki DT1000
1979 RD400F Daytona Special
