Rebore
Rebore
I had some barrels bought second hand several years a go and they came with 1.00 rebore and fresh pistons, never ran
Fitted them and they rattled but not terminal, so rode it like this for a few years then I changed barrels
Now I'm building the second bike and took these barrels in to the local engineers and he reckoned 1.25mm over might not be enough to clean them up and said 1.50mm might be what they end up but said he would ring me first
Is this normal then to jump 2 sizes , there was scoring but nothing looked deep
That original 1.00 re bore though was never right even though it went like stink and made 68bhp on those barrels with a Mick Abbey tune
Also if I end up with 1.50mm bores, will the head gasket still be OK , as in no trimming of the inside diameter ?
Re: Rebore
It's more about getting the bore round than taking out scoring. He's probably come to that conclusion because the bores are slightly oval, so you'll just have to jump 2 sizes if that's what it takes to get I back in shape. If it was loose in the first place that will have accelerated the process in wearing the bores oval.
Re: Rebore
I had better accept the 1.50mm re bore then !
Won't have much life left in them then ?
There is always the question to what is the maximum you can bore YPVS 350 barrels out to
Is 2.00mm the limit really ?
I have some more barrels on 0.5mm but haven't got the Mick Abbey tune on them
Re: Rebore
Can't you just have a new steel liner pressed in when they get to the end of their life? Get the ports re dressed to match the ally and you're good to go again
Re: Rebore
Well you'll get more life out of the bore if you change the pistons more regularly and that's certainly cheaper than re sleeving it
- T.RexRacing
Re: Rebore
Yeah I do pistons every 10K miles or so. Bore usually lasts 3 pistons before needing work.
Salvador Dali
Salvador Dali
Re: Rebore
...except the liner is cast in the jug. Most are pressed in.yazza54 wrote:Can't you just have a new steel liner pressed in when they get to the end of their life? Get the ports re dressed to match the ally and you're good to go again
Replacing the liner is doable but it probably easier to find replacement jugs.
Re: Rebore
Yeah I can't say I'm keen on re sleeves
I do have some more barrels but don't have the famous Mick Abbey tune (UK)
Re: Rebore
Do you have any one who can plate your cylinders? There are a couple here in the US that do it. It is expensive but maybe worth it if you like your porting.
Re: Rebore
Engineering place just rang and they put the 1.50mm bore through and it still hasn't cleaned up the inlet sides and he now is going 1.75mm which is a shocker really as I didn't expect that and that might not do it !
I have some more barrels on 0.5mm but haven't got the tune , so a big dilemma what to do
Re: Rebore
Must say that is quite surprising. I had a pair of barrels that had been bored crooked and only took .5mm to correct.
Re: Rebore
They are a well used firm here in the UK and are a handful of trusted places to use but I don't like this at all !
Re: Rebore
My current set of cylinders is +3.25 mm but the liner is thin as paper in some locations.
I'd consider them as 'to be resleeved' after the next damage.
Going bigger than expected is normal as usually the bore is not perpendicular to both sealing surfaces. So you always need some 10'th to compensate that.
Second issue is that re-bore was done out of center. That may rob you a few overbore sizes at the end of the life.
Re: Rebore
3.25, is that a typo ? Did you mean 2.25mm
Wow I only thought 2.00 was the max or 2.25 for the brave !
