Rebore
Re: Rebore
#16 Post by MK » Thu Aug 10, 2017 12:18 pm
Nope.
Bought +2.5 Woessner as the last common size and it wasn't enough to compensate the old bore misalignment.
So I got +3.25 Woessners for Banshee big bore kits and the were sufficient. As I said it was a very tight fit and took a skilled mechanic to do the bore/hone job.
Btw: still have the unused +2.5 set of Woessners for sale. Make a sensible offer and they can be yours soon ;-)
Headcoats
Re: Rebore
#17 Post by Headcoats » Thu Aug 10, 2017 12:58 pm
Fair play
Did you have to trim the power valves too ?
Re: Rebore
#18 Post by MK » Thu Aug 10, 2017 1:33 pm
Sure. That's another piece in the puzzle that leads to the point of no return :-)
Headcoats
Re: Rebore
#19 Post by Headcoats » Thu Aug 10, 2017 2:03 pm
Have you any pictures of this mighty engineering :smt035
(F5)
Re: Rebore
#20 Post by (F5) » Thu Aug 10, 2017 4:19 pm
US chrome can plate steel bores. Its a bit expensive but not really. My racing 50 lasted 10 years of 13,000+ rpm before the bore became too oval to make full power again.
First crowd who did it plating fell off. Its not as easy as plating ally.
Headcoats
Re: Rebore
#21 Post by Headcoats » Sat Aug 12, 2017 6:03 pm
Still waiting for the phone call to see if the 1.75mm bore was a success !
Too scared to ring myself LOL
Headcoats
Re: Rebore
#22 Post by Headcoats » Wed Aug 16, 2017 4:56 pm
They rang today to say my barrels were done at 1.75mm rebore :smt012
So that's 3 rebore sizes up from when I first took my barrels in to be done :smt021
Out of interest . what CC are my barrels now ?
waltmil
Re: Rebore
#23 Post by waltmil » Thu Aug 17, 2017 4:38 am
It comes out to 366.7, an increase of 5.6%.
Headcoats
Re: Rebore
#24 Post by Headcoats » Thu Aug 17, 2017 9:54 am
Thanks for that
Just tell myself I have a big bore kit now just to cheer myself up !
Re: Rebore
#25 Post by MK » Thu Aug 17, 2017 2:50 pm
Headcoats wrote:Have you any pictures of this mighty engineering :smt035
Like this ?
Headcoats
Re: Rebore
#26 Post by Headcoats » Wed Sep 06, 2017 4:46 am
Looking at some 400cc (392cc) Banshee type barrels and was looking at the Athena top end kit but was told the quality isn't great
Anyone had one of these kits ?
Other folks mentioned "Serval" but I know nothing about these so if anyone could shed some light on this please ?
two-stroke-brit
Re: Rebore
#27 Post by two-stroke-brit » Wed Sep 06, 2017 8:10 am
Headcoats wrote:Looking at some 400cc (392cc) Banshee type barrels and was looking at the Athena top end kit but was told the quality isn't great
i have an Athena 392 bore and head on my hybrid .
i have not done a lot of miles on it because waiting on a set of TSA pipes.
i have a Spec11 pipes currently fitted and it goes as expected.
HTH Mark
Headcoats
Re: Rebore
#28 Post by Headcoats » Fri Sep 08, 2017 5:27 am
What are these "bungs" that have to go in the cylinders to make water tight ?
Are they problematic ?
Did you keep the pistons that came with the kit and what did you do about the wrong positioned coolant pipe on the Athena head ?
Headcoats
Re: Rebore
#29 Post by Headcoats » Fri Oct 06, 2017 4:17 pm
Finally got the barrels back today with the fresh bore and 1.75mm pistons !
Looking at the remaining liner, there is about a 2mm thickness left , if that is even, I suspect not
Headcoats
Re: Rebore
#30 Post by Headcoats » Sun Oct 08, 2017 8:13 am
Image 1.75[/url]
Well I picked them up at last !
