Lubrication holes in piston skirts good idea or not.
steeley
Re: Lubrication holes in piston skirts good idea or not.
#16 Post by steeley » Sun Sep 03, 2017 5:46 am
Hi , not been here for some time . On all the engines I have rebuilt /2 stroke ,I chamfer the bottom edge of the pistons off to help stop the sharp edge scraping the oil off . Works for me.
tankslap
#17 Post by tankslap » Mon Sep 04, 2017 9:53 pm
MK, have you got any pictures of your racebike you can upload or a link to a build thread?
Looks like an interesting bike from the photo of you in action on one of the other threads that you posted.
Sent from my SM-G920I using Tapatalk
#18 Post by MK » Tue Sep 05, 2017 9:22 am
Well there is no explicit build thread.
It's just been used and optimized over the years. (And never been cleaned :-) )
tankslap
#19 Post by tankslap » Wed Sep 06, 2017 9:17 am
Well time you started one!..;)
My bikes rarely get cleaned either. The crud on the BST wheel on the back of my SV just has my friends shaking their heads in disgust.
The mismatched wheels and R6 forks and general purposefull tardiness is just something I get so more pics please.
And on subject I put little oil dimples on some Wossners in a 421 Athena with a ball shaped 1/8 carbide bur. If there isn't any sharp edges to create a stress raiser then I can't see it doing any harm.
#20 Post by MK » Fri Sep 08, 2017 2:39 pm
Here you go. Pics from last Monday in Pottendijk
https://photos.app.goo.gl/2EtWlYUZKotOkP6I3" onclick="window.open(this.href);return false;
https://photos.app.goo.gl/sBrRM2pNtlv9tCAC3" onclick="window.open(this.href);return false;
https://photos.app.goo.gl/a8UzPneaxnaeyjh22" onclick="window.open(this.href);return false;
South_Oz
#21 Post by South_Oz » Sun Sep 10, 2017 5:02 am
Interesting air box.
Dave
RZ 250 85 (Waiting)
RZ 250 85 (Parts)
BMW R1100S 99 (Its Red)
BMW R1200GS (Its BIG)
graham heise
#22 Post by graham heise » Tue Sep 12, 2017 7:03 am
is there anything left to modify on your bike martin? looks the business.
yamaha fanatic.
tankslap
#23 Post by tankslap » Tue Sep 12, 2017 7:32 am
Thanks MK, interesting airbox and RGV carbs? The steering head angle looks quite steep. Has the frame been de-raked or is it an optical illusion?
Good choice of forks. 41mm Kayaba R6 forks? Have you done anything to the valving?
Also why the spoked rear rim? Was it just something you had lying around or is there a performance advantage?
Did you make the fuel tank?
Part of the reason I'm quite interested in this bike is that the only race tracks close enough to me are kart tracks. I have an Aprillia rs125 which I'm converting to kart track use.
The mods/ specifications for this type of track use are a bit different to fast road race tracks.
What type of bikes do the competition run and how does
your RZ compare? My main competition will be RS125 Honda's and CBR250rr's.
Sent from my SM-T805Y using Tapatalk
