Splitting cases...
expat
Splitting cases...
#1 Post by expat » Sat Sep 02, 2017 5:36 pm
I am doing a restoration for a friend and want to have the crankcase halves vapor blasted and the top repainted.
Is it possible to split the cases without removing the clutch and flywheel?
My plan was to unbolt, flip the motor, vapor blast the bottom half, reassemble, flip and then blast the top half before buttoning it all back together...
removing the clutch and flywheel is not an issue, just trying to save some hours!
85 RZ350
88 YSR50
82 RD350LC (Current project)
97 Honda RS125 (race bike #1)
89 RGV250 VJ21
85 RG500
85 RZ350 Hybrid
86 GSXR750
tacky1
Re: Splitting cases...
#2 Post by tacky1 » Sat Sep 02, 2017 6:16 pm
Nope, You need to remove both, The stator behind the flywheel bolts to both halves and there is a bearing holder behind the clutch bolted to both halves
expat
#3 Post by expat » Sat Sep 02, 2017 11:43 pm
tacky1 wrote:Nope, You need to remove both, The stator behind the flywheel bolts to both halves and there is a bearing holder behind the clutch bolted to both halves
Thought there may be something like that. Thanks for the info, it's in the manual I can't find I am sure!!
85 RZ350
88 YSR50
89 RGV250 VJ21
85 RG500
85 RZ350 Hybrid
86 GSXR750
OldTZracer
#4 Post by OldTZracer » Sun Sep 03, 2017 1:54 am
I'm not sure how much time you'd actually save. The vapour blast grit gets into everything.
