Jetting
emartinez
Jetting
#1 Post by emartinez » Thu Sep 07, 2017 3:31 am
I have 83 rz ported cylinders stock head zeel ignition stock banshee crank vforce 4 with spacer 28 mm Keihn pwk foam pods old spec 11 pipes I live at sea level where to start with jetting and I premix 32/1
Disco
Re: Jetting
#2 Post by Disco » Thu Sep 07, 2017 12:47 pm
What is your jetting now and what issues with it do you have? That's the starting point.
Go 40:1 on premix with quality oil. That's a good place to begin also.
emartinez
Re: Jetting
#3 Post by emartinez » Thu Sep 07, 2017 3:52 pm
I have not started it up yet the jets I have are 132,135,138, and 42, 45, that's the jets they gave me niddle is in the middle
tacky1
Re: Jetting
#4 Post by tacky1 » Fri Sep 08, 2017 12:04 am
Your setup sound very much like mine,
I am running the oil pump though.
This is my jetting for the PWK and it pulls clean all the way into the red in top gear with no problem on stock gearing.
JJH Needle second slot from the bottom.
40 Pilots and 130 mains
emartinez
Re: Jetting
#5 Post by emartinez » Fri Sep 08, 2017 2:45 am
Cool thanks for your support
