LOWER CASES ALL THE SAME OR?
TN-592
#1 Post by TN-592 » Wed Sep 13, 2017 8:01 am
I was trying to trenched rd350 31k cases for the 10 mil setup,forgot to change the tool setting in the cnc machine so now i have a hole in the cases.
Was trying to buy another lower unit on ebay but there i can just find cases from year 74 and so.....on
My question is are all lower cases the same,which can i fit on the 31k transmision and upper unit case?
Hooligan
Re: LOWER CASES ALL THE SAME OR?
#2 Post by Hooligan » Wed Sep 13, 2017 4:22 pm
Is the new hole in a bad place? Just tap it and thread in a plug would seem to be the easiest and cheapest fix.
T.RexRacing
#3 Post by T.RexRacing » Wed Sep 13, 2017 9:20 pm
The crank bearing bores are line bored. Not a good idea mixing cases.
Salvador Dali
#4 Post by JonW » Wed Sep 13, 2017 9:57 pm
you need a matched set of cases as Trex says, they are numbered for that reason on the stator side.
Weld up the hole, easy...
Zedixe13
#5 Post by Zedixe13 » Thu Sep 14, 2017 6:32 pm
I have an undamaged 1983 case if you need one .
TN-592
#6 Post by TN-592 » Sat Sep 16, 2017 5:06 pm
Thank you all for your replys
Since it is not so smart to mix cases first i will try to weld or epoxy the hole
