Best pistons for 1991 RD350F2 1WT
sedsberg
#1 Post by sedsberg » Sun Dec 10, 2017 8:27 pm
Had my cylinders rebored a couple of years ago and I suspect the supplied pistons are som cheap, rubbish pistons. I've gotten that before from the same shop (for a different bike). Planning on changing them next summer.
What pistons are recommended for this bike?
1990 RD350 F2 1WT
evan_calgary
Re: Best pistons for 1991 RD350F2 1WT
#2 Post by evan_calgary » Mon Dec 11, 2017 12:49 pm
There is no 'best' piston in my opinion. Go buy wiseco if you want peace of mind. Otherwise all of the usual companies such as Namura and even CruisinImage off eBay make fine pistons...It is very rare you hear of a failure actually due to the piston these days and most of these bikes are quite low mileage. What is your concern? Tolerance?
Sure there will be some strong opinions that come up though. Can't say my honing/boring specialist has had any issues when I brought up the topic and that and building motors is all he does...
#3 Post by JonW » Mon Dec 11, 2017 8:06 pm
Amusingly the cheapo CruisinImage pistons are actually pretty good, the nasty ones Ive seen recently are the Tawianese Mitaka units; cast by a child.
evan_calgary
#4 Post by evan_calgary » Mon Dec 11, 2017 9:37 pm
Other than poor casting, weight and dimension tolerance, I am not sure what qualifies as a 'bad' piston. You hear the odd story of someone having an early failure but it is rarely first hand or recent and the other qualifying factors that could be user error are not identified.
#5 Post by hondaror » Mon Dec 11, 2017 9:40 pm
JonW wrote:Amusingly the cheapo CruisinImage pistons are actually pretty good, the nasty ones Ive seen recently are the Tawianese Mitaka units; cast by a child.
Jon, you mean, cast by a child with no skills. Some kids I know, do a better job then many adults.
#6 Post by hondaror » Mon Dec 11, 2017 9:40 pm
#7 Post by JonW » Tue Dec 12, 2017 12:40 am
LOL! And of course, youre right... I'd say they were cast by a child with a lesser skill level than the ones who made Raasks back in the 70/80s... and that's sayin something LOL!
Truly, they were really bad; inclusions and dents from things in the badly made mould and flashing still evident in the ports. Really nasty. Do not buy them.
sedsberg
#8 Post by sedsberg » Tue Dec 12, 2017 12:28 pm
I've gotten pistons from this shop that had the piston ring retaining pin falling out during assembly. THe boxes are unbranded and the invoice just says "piston".
I can't find Wiseco for the newer RD350s. Just for the old air cooled ones.
1990 RD350 F2 1WT
75RD350rider
#9 Post by 75RD350rider » Tue Dec 12, 2017 1:26 pm
http://www.fastfromthepast.com/pistons/yamaha" onclick="window.open(this.href);return false;
I have heard very good things about these and when top end time for my RZ comes I am gonna try a set.
Tim Steele in Front Royal, VA
#10 Post by JonW » Tue Dec 12, 2017 7:13 pm
sedsberg wrote:I've gotten pistons from this shop that had the piston ring retaining pin falling out during assembly. THe boxes are unbranded and the invoice just says "piston".
youre not searching hard enough, try adding Banshee to your search.
sedsberg
#11 Post by sedsberg » Tue Dec 12, 2017 10:25 pm
I've never seen it confirmed that banshee and RD350 pistons are the same. But I take it they are.
1990 RD350 F2 1WT
justind97
#12 Post by justind97 » Tue Dec 12, 2017 10:59 pm
sedsberg wrote:I've never seen it confirmed that banshee and RD350 pistons are the same. But I take it they are.
Identical. Providing you stipulate RD350 YPVS. North America got RZ350 as a name.
#13 Post by JonW » Tue Dec 12, 2017 11:47 pm
just remove the tangs if fitting to an LC.
This info is all over the forums...
sedsberg
#14 Post by sedsberg » Fri Dec 15, 2017 4:47 pm
Thanks. So I assume I should be OK if I buy any name brand?
1990 RD350 F2 1WT
evan_calgary
#15 Post by evan_calgary » Fri Dec 15, 2017 7:15 pm
You got it! Banshee pistons are the same thing. Just cut off the tab if using on LC. Any big name brand piston will do you fine. If you want to save a few bucks check out Cruzinimage on eBay. I have also had no issues with Mitaka pistons nor casting issues on other 2-strokes!
