Needle Valve bowl gasket
Ethanol is just killing these gaskets in my LC. Heard a remedy was to smear gas resistant gasket paste on the rubber but I imagine that action would glue the bowl in permanently into the carb and residual paste could potentially block the orfice at the bottom of the bowl when pushing it into the carb. Other that buying the whole assembly for the bowl, does anyone know where to buy just the rubber gasket that fits?
- IMG_3861.JPG (123.38 KiB) Viewed 1822 times
- Evans Ward
Re: Needle Valve bowl gasket
Very good question! Will be watching this thread.
- two-stroke-brit
i use a gas resistant grease on leaky petcocks that works good.
"Gas EZ" rings a bell, but i will post the proper name if i am in error.
there must be an o-ring to suit for pennies.
mark
mark
You should be using Esso premium or Shell V premium. No ethanol.
It looks like an oring from the picture. I would think it would be possible to source one that is made of viton...But as Rory said if you have ethanol free fuel available then I would use that if feasable.
Tim Steele in Front Royal, VA
Not all the surrounding communities have Chevron (no ethanol) available & are beyond the gas tank capacity. Did some micrometer measurments and the closest is a M1 Vitron O Ring 75 Durameter (might be a bit hard) 7mm ID, 9mm OD, 1mm thickness might do the trick. Learnt that vasoline is the choice of lubricant for the o-ring installation as it washes away when in contact with heat or fuel. Apparently vasoline is also used to put transmissions together - i.e hold bearings in place during re-assembly. Apart from the usual searches, off to hunt for the o-ring(s) in parts shops to see if they do fit properly.
Do yourself a favor and search Pure-gas.org and find ethanol free stations near you. Fyi they list 795 in Florida alone.
- two-stroke-brit
There are none in houston as the city mandates a 10% ethenal min..waltmil wrote:Do yourself a favor and search Pure-gas.org and find ethanol free stations near you. Fyi they list 795 in Florida alone.
but out of town it can be found
- Evans Ward
Yes, that pure gas site is awesome! I use it when traveling too.
That O ring looks to be a special size/ design with none of my Viton kits matching it. Will still watch for a perfect match one for some needed spares.
Evan which Viton o ring sizes did you eliminate from your kit?
- Evans Ward
Didn't write them down- would have to try fitment again.LC Cnd wrote:Evan which Viton o ring sizes did you eliminate from your kit?
EZ Turn is the gas resistant grease that I use.two-stroke-brit wrote:i use a gas resistant grease on leaky petcocks that works good.
mark
Found a photo of the stuff on a Kawi site. Tryed to purchase if on an aircraft website but did not work(?). It appears EZ is quite specialized as I did not see it for purchase on Amazon. May have found a Viton o ring (.50 each) that may match RZ/RD one on a tractor website - go figure. Price is sorta alright but not sure about the size. Found nitrle one that fits so close and with the EZ Turn that would be plan B. Its the cross section diameter, of the o ring, that the tricky bit to provide the right squish factor. The closest I found was an M1 (standard mft size). Suspect there is a supplier out there somewhere in South East Asia producing these bits at .05 a unit or less 4 Alibaba abeit with a min order of 1000 or so.
- ez-turn_1.jpg (121.97 KiB) Viewed 1667 times
I have a set of TZR250 downdraft carbs that are just destroyed by ethanol. I'll post pics when I find them. It eats aluminum.
The left o ring is stock; the right what is in the package. The new one is taller but literally 'clicked' in place. Problem solved for $3 (got 20) outta Vancouver. The item lists it as FPM which is the same material as Viton hence ethanol resistant. What a money saver! Cheers - Scott.
- IMG_3867.JPG (112.14 KiB) Viewed 1530 times
- IMG_3870.JPG (118.61 KiB) Viewed 1530 times
