Vforce Reed chip Question
Re: Vforce Reed chip Question
Jon, do you know if the dyno shows a performance difference?
for VFs over stock cages, yes, Ive seen it proved.
No, the fibreglass vs the carbon.
- T.RexRacing
Fiber TDR reeds are tough. I have a set that were in the bike 5 years and are still usable. Only reason they're not in there is trying some OEM (fiber) Banshee reeds. Jury's out on them so far.
Salvador Dali
Salvador Dali
Lots more posts here since I last checked in!
Carbon is substantially stiffer than fiberglass. Quite a bit. It can be felt in a low-tech composite made in the garage of similar weight fabrics of the 2 materials. A quick google search mentions the above in every post but the numbers comparison is usually to steel. Fiberglass is more flexible therefore less likely to chip. I am surprised to see the manufactures using a twill fabric vs. a uni-directional as well which would provide even more strength. Possibly the impacts with the cage face are not 100% even in the lateral direction or just haven't had the need to update the tech.
Carbon = Stiffer, Glass = more durable
I find this odd. I thought the only difference was with the matting used within the reed.evan_calgary wrote:Lots more posts here since I last checked in!
It is Rory. Carbon is a stiffer and stronger material. Straight fibers are stronger than bent fibers. regular weave is a constant bending mesh of fibers, up and over, under and through. Fiberglass is a more flexible material than carbon when it comes to fiber strength. Unidirectional weave is used in carbon frames for supercars as it is the strongest most rigid material available.
