Vforce Reed chip Question
Re: Vforce Reed chip Question
#16 Post by hondaror » Sun Jan 07, 2018 5:52 pm
Jon, do you know if the dyno shows a performance difference?
#17 Post by JonW » Sun Jan 07, 2018 6:47 pm
for VFs over stock cages, yes, Ive seen it proved.
#18 Post by hondaror » Mon Jan 08, 2018 1:34 am
No, the fibreglass vs the carbon.
Headcoats
#19 Post by Headcoats » Mon Jan 08, 2018 7:03 am
Plus which ones are more durable ?
T.RexRacing
#20 Post by T.RexRacing » Mon Jan 08, 2018 11:51 am
Fiber TDR reeds are tough. I have a set that were in the bike 5 years and are still usable. Only reason they're not in there is trying some OEM (fiber) Banshee reeds. Jury's out on them so far.
Salvador Dali
evan_calgary
#21 Post by evan_calgary » Tue Jan 09, 2018 4:02 am
Lots more posts here since I last checked in!
Carbon is substantially stiffer than fiberglass. Quite a bit. It can be felt in a low-tech composite made in the garage of similar weight fabrics of the 2 materials. A quick google search mentions the above in every post but the numbers comparison is usually to steel. Fiberglass is more flexible therefore less likely to chip. I am surprised to see the manufactures using a twill fabric vs. a uni-directional as well which would provide even more strength. Possibly the impacts with the cage face are not 100% even in the lateral direction or just haven't had the need to update the tech.
Carbon = Stiffer, Glass = more durable
#22 Post by hondaror » Wed Jan 10, 2018 11:34 pm
evan_calgary wrote:Lots more posts here since I last checked in!
I find this odd. I thought the only difference was with the matting used within the reed.
evan_calgary
#23 Post by evan_calgary » Thu Jan 11, 2018 4:15 am
It is Rory. Carbon is a stiffer and stronger material. Straight fibers are stronger than bent fibers. regular weave is a constant bending mesh of fibers, up and over, under and through. Fiberglass is a more flexible material than carbon when it comes to fiber strength. Unidirectional weave is used in carbon frames for supercars as it is the strongest most rigid material available.
