Vforce Reed chip Question
evan_calgary
#1 Post by evan_calgary » Sun Dec 31, 2017 7:14 pm
Looking at a set of Vforce 4's. There is a small chip top corner of one reed petal. Likely 3-5mm in size.
Owner said this was from install. Not sure this sounds right.
Wondering if this chip will lead to further and if a new petal is required?
Further chipping could lead to hard carbon slivers in my main bearings correct?
JonW
Re: Vforce Reed chip Question
#2 Post by JonW » Sun Dec 31, 2017 8:13 pm
Hmm, any damage means more to come with these. defo needs a new petal.
evan_calgary
#3 Post by evan_calgary » Mon Jan 01, 2018 6:34 pm
Thanks Jon. That was my thought as well. Maybe if it wasn't directly in line with the crank I would risk it but expensive potential damage.
JonW
#4 Post by JonW » Mon Jan 01, 2018 7:57 pm
Yeah Im not 100% sure just how much damage carbon fibre in the crank bearings would do, Im thinking less than steel as it would get chopped up pretty quickly, but I would suggest that a chipped petal is not the place you want to start with a set of reeds, did you scope out what a reed petal costs from Vforce? I doubt they'd be cheap, but one can hope?
evan_calgary
#5 Post by evan_calgary » Mon Jan 01, 2018 9:25 pm
Looks like about US60 per reed. Deal breaker for me.
JonW
#6 Post by JonW » Mon Jan 01, 2018 9:56 pm
Ouch... I hear you Evan.
kenny
#7 Post by kenny » Tue Jan 02, 2018 9:44 am
evan_calgary wrote:Looks like about US60 per reed. Deal breaker for me.
Contact Tony on here he makes reeds TDR50 is his username.
Headcoats
#8 Post by Headcoats » Sat Jan 06, 2018 7:50 am
What sort of prices does Tony charge then please ?
I have always used V3 and V4 reed blocks but beginning to think if using standard blocks with carbon reeds would be more cost effective without too much loss in power ?
T.RexRacing
#9 Post by T.RexRacing » Sat Jan 06, 2018 9:31 am
Try TDR's fiber reeds. I ran them for years and never an issue. I see no advantages in carbon reeds. it's not like a poppet valve where weight is a consideration. Stiffness is the key and weight is nil. TDR's RZ reeds are available straight from TDR or John @ Economy Cycle sells them as well.
Salvador Dali
JonW
#10 Post by JonW » Sat Jan 06, 2018 10:17 am
And also on ebay i think?
I dont think standard cages would flow quite the same as the Vforce, but would be cheaper. You can run banshee grp reeds as well if worried about the old steels.
bjacobsen
#11 Post by bjacobsen » Sat Jan 06, 2018 3:42 pm
TDR makes replacement reed petals for the v-force 4 in both carbon or fiberglass.
JonW
#12 Post by JonW » Sat Jan 06, 2018 6:53 pm
Thats great news, has to be cheaper than OEM surely.
bjacobsen
#13 Post by bjacobsen » Sun Jan 07, 2018 1:28 am
Just looked on TDR's site, full set of 8 petals for the vf-4 is $65(fiberglass) and $80(carbon)
hondaror
#14 Post by hondaror » Sun Jan 07, 2018 5:44 pm
Not sure why you'd even consider carbon here. Unless the casing is a different stiffness. Maybe Tony will comment.
JonW
#15 Post by JonW » Sun Jan 07, 2018 5:50 pm
The OEM VForce reeds are carbon, you'd replace them with the same I would think.
