It is currently Mon Oct 22, 2018 1:32 am
Post new topic Reply to topic  [ 6 posts ]
PostPosted: Sat Feb 03, 2018 5:07 pm
I have found this chinese copy of keihin pwk for 54usd,did anyone had any experience with these carbs?
https://www.ebay.com/itm/Keihin-PWK-38m ... c7&vxp=mtr
PostPosted: Sat Feb 03, 2018 11:23 pm
Don't do it. Buy a new set of decent Mikuni flat slides!
The build quality is terible, and the Chinese carbs that I sonic cleaned, turned a very dirty, blackish swirly gray.
I would not trust them with any of my engines.
PostPosted: Fri May 25, 2018 1:30 am
I was given a set of these and realized they are airstrikers with the fins polished out of the Venturi, you would think no big deal but apparently it is because where the nozzle protrudes into the Venturi it needs a hood, well that was messed up too and it had some wild jetting needed, we spent a 1/2 day on the Dyno and could not get them to perform, it had stripped screw and something else, I said that's enough of that, I stand with Rory
PostPosted: Fri May 25, 2018 5:07 am
Just not worth the risk and that goes for genuine jets, needles etc
PostPosted: Mon Jul 02, 2018 11:38 pm
:-) Buy cheap = Buy twice !
And if Dim... repeatedly.
PostPosted: Tue Jul 03, 2018 2:23 pm
If you make the cheap attempt, at least use the real Mikuni jets. The Chinese stuff has no tolerances required for the manufacturing. They reverse engineer.
Your jetting will cost more then the carbs, and they still may not run right, ever.
Users browsing this forum: No registered users and 8 guests
