Copper Head Gaskets
Headcoats
Copper Head Gaskets
#1 Post by Headcoats » Sun Feb 04, 2018 6:54 pm
Are they worth looking at ?
Anyone on here had experiences good or bad please :smt002
Re: Copper Head Gaskets
#2 Post by hondaror » Sun Feb 04, 2018 7:27 pm
The concept is good. You can anneal them and reuse them. The key is to get the right thickness to coincide with your clearance needs, squish.
Headcoats
#3 Post by Headcoats » Mon Feb 05, 2018 5:56 am
I'm more on about how they seal against standard head gaskets
Seems you need to add a little sealant to the copper surfaces or not ?
Our engines are getting worn out now after 30 years and the mating surfaces aren't pristine are they ?
T.RexRacing
#4 Post by T.RexRacing » Mon Feb 05, 2018 11:58 am
OEM head gaskets seal well. As do copper gaskets. If the surfaces aren't flat machine them as a gasket isn't going to fix that.
Salvador Dali
kpke
#5 Post by kpke » Mon Feb 05, 2018 12:11 pm
I have installed one however, the engine has not been started yet so not very helpful :smt009
Spray on Permatex? was used on both sides per the gasket sellers instructions.
When I get to starting it I will report back in my long-lost build thread.
Headcoats
#6 Post by Headcoats » Mon Feb 05, 2018 12:30 pm
Yes these gaskets are tempting , especially if you can reuse them
Evans Ward
#7 Post by Evans Ward » Mon Feb 05, 2018 1:52 pm
I'm considering one on my upcoming RZ rebuild. I've reannealed plenty of copper Kaw Triple head gaskets with success.
Hooligan
#8 Post by Hooligan » Thu Mar 29, 2018 6:50 pm
I tried one on my RZ and it didn't work at all. Failed almost immediately and blew pressure into the cooling system. I had coated both sides with spray on Permatex.
Swapped to an OEM gasket and everything was fine.
Evans Ward
#9 Post by Evans Ward » Thu Mar 29, 2018 7:03 pm
I've decided to stay with the stock OEM one for the present build.
waltmil
#10 Post by waltmil » Fri Mar 30, 2018 6:18 pm
Copper works great for air cooled.
Bare
#11 Post by Bare » Sat Mar 31, 2018 11:26 pm
Been there done the Copper gasket nonsense in Early 70's.
It proved a total exercise in frustration.
Avoid the crap at All costs.
As One example.. the reusabilty claim is total BS.
Copper takes an imprint from the cyls/head.
Yess even at the silly 20 ft lbs Yamma torques.
HOW? you planning on restoring the dented surfaces for the next use.. 'nuff said
