Stripped Engine Bolts in case
Need some help here. I stripped the screws that hold the retaining plate for the transmission in the crankcase. and to compound upon it the heads broke. Im going to take my case to a machine shop to drill out and helicoil the case to make it useable again. Can somebody share the size and pitch of the screws used. It is #15 in the diagram.
- Screen Shot 2018-02-07 at 9.25.16 PM.png (123.08 KiB) Viewed 2087 times
Re: Stripped Engine Bolts in case
This is the answer to all your problem ,
https://www.ebay.ca/itm/Neiko-10038A-Le ... Sw6ShZOkyo
I bought this kit and used them with a simple reversible drill , in 30 sec. the broken bolt was out .
ive never had any luck with my set like that, upside down bolts work differently perhaps lol
spark erosion is a good technique to get them out if totally stuck.
LH drill bits and square end easy outs worked for me on the opposite plate, these were the counter sunk screws whose heads had been stripped before i got to them
Use the smallest drill possible and centre punch the head of the screw first, tap the easy out in as far as possible, take it slow and careful and they should come out
A bit of freezit spray on the screw also helps too
When i went that route, the bit walked on me so it cut into the threads on the case just enough that the square extractor no longer works. It HAS to get helicoiled now (or some kind of thread repair). A bit frustrating, so thats why i need to know the screw size and pitch.
These screws are notorious for refusing to budge and then strip
Welding a nut on the screw will do the job and the heat helps to loosen it too
- T.RexRacing
Avoid EasyOut tools. There are other fastener removal tools that don't break off making things worse.
First I take a good chisel and make a slot in the remaining screw. Heat with a heat gun to loosen and try removing with flat head screwdriver. If that fails the left hand drill bits are next. Then use the removal tools that come with my left hand drill bits. That fails and it's into the mill and gently cut out with carbide end mills.
Salvador Dali
Salvador Dali
Another tip is to impact the end to shock the threads loose, before you try and back them out. Hit them hard and often enough and they'll back right out.
M6x1.0
Next time use a impact driver and heat. Those screws have thread locker on them.
If you are going to drill it out, use the hardest, stoutest drill you can find. A carbide spotting drill works well.
Removing broken bolts is an art form that only comes with experience... meaning you're going to screw up a bunch of 'em till you figure it out.
Real "Easy Outs" are great. I haven't seen a real "easy out" in years, just crappy knock offs made from oriental monkey metal, that twist off the first time you use them.
I have had good luck using Ridgid Pipe extractors.
I have had a set of these for at least 30 years... the small one is getting kinda short though.
This is all sound advice IMHO. I use a Vessel impact screwdriver these days, its the correct JIS type for the screws and the impacta unit in it works very well.bitzz wrote:M6x1.0
Its defo an art form, Im much better at it now than I ever was, plus I have a full set of helicoils on hand for when it all goes wrong, but rarely get to use em.
Replace with hex drive/allen head bolts/screws.
I used ss with nickle silver never seize.
As L.B. Says, antisieze is really important with dissimilar metals.L.B wrote:Replace with hex drive/allen head bolts/screws.
- T.RexRacing
Cleaning threads on assembly is important. Some threads are to be oiled,check manual. When using anti-sieze or other lubricants torque must be reduced to avoid over tightening-UNLESS manual directs you to lube threads. Unless specified torque specs are for dry clean threads.
Salvador Dali
Salvador Dali
