Leaking mikuni carb
Leaking mikuni carb
Fired up the LC friday and noted the right non choke carb (VM26) leaking (streaming) out the bottom over flow at the bottom of the petcock. Reset the floats to 21mm. Cleaned everything, reset the float height - still leaking. Changed the o ring on the float bowl to a new one again. Leaked. Took basso and slowly twisted the steel needle (new with a new float bowl) around until there was a grey mark on the needle tip. Tested the float - it floats. Tested it again - Leaked again. Put rubber tipped needle (RZ) and the carb leaked intermittently. Changed the float bowl and o ring again - still leaked and weak compression from the right exansion chamber. Some how, I suspect, the needle or the floats are snagging on something but can't see what. The float bowl is the proper one. What"s the issue cause I have run out of ideas. The choke carb is running perfect.
Re: Leaking mikuni carb
Did, at any time, you hit the carb float area with the handle of a screw driver? The shock sometimes, will cause the float needle to seat. Every once in a while, float assemblies will act up.
yep, always adopt the tap method. no need to hit hard, shock it dont dent it...
Reminds me of a mate I recommend that method in the early 90's.
The bloody jerk didn't remember which side of the screwdriver to tick against the float bowl and he thought the harder the better.
Ended with ordering a new one from the friendly local Yamaha dealership...
(To his defense I should mention he was a banker and not a mechanic)
Lol, Martin. That is why I said, with the handle of the screw driver.
Huh. Reminds me when a soft drink can/bottle would get stuck by not dropping to the bottom of the cooler after payment - one quick smack on the side - voila. I'll give it a light tap out in the driveway after the Arctic out flow leaves the neighbourhood. Thx gents.
Needle and seat? If the float floats and is set proper, then it has to be needle and seat problem I would think. You mention replacing the needle but not the seat. Just a thought.
If the tapping does nothing, you can use a chop stick to dress the float valve seat. You may have to whittle the chop stick down to size to get contact with the seat. Lap it like a valve. This action will hopefully soften any burrs that may be causing the valve seat to leak.
You should replace both parts on these old carbs, as a rule of thumb.
Check that the over flow pipe isn't cracked inside the float bowl. They've caused exasperation to many people by leaking gas when there's nothing wrong else where.
Dave.
Dave.
Thx Dave. Ck'd it using water and it appear tight. However I am going to switch it with another. Did the ball bearing trick as I thought that would round out the opening at the bottom of the float bowl prior to lapping. The bowl is new; so is the needle. As noted in the photo the needle finish is not mirror-like. More lapping perhaps. But the tap might do the trick.
- IMG_3891.JPG (78.32 KiB) Viewed 2651 times
Further investigation revealed none of the carb parts were the issue - it was minute debris (weld material?) from the bottom of the mini gas tank that flaked off jamming the needles open while carb syncing. The tank's un-removable fine mesh screen blocks any view below the screen where it appears the flakes oringinate. Everytime I tapped the carbs to settle the needles would dislodge the debris until the next time I opened the tank for more fuel. Hopefully a flushing of carb cleaner here will clean the tank.
- IMG_3901.JPG (44.18 KiB) Viewed 2427 times
Great that you found that out. Glad you shared this info. Kind of crazy how fragile the system is.
well done for working it out!
