Best 2 stroke injector oil
Re: Best 2 stroke injector oil
I have been using Maxima 927 which is a castor based oil and it burns clean as a whistle. I have never had any engine problems and I use it in all my twostroke stuff.
1984 Rz350, Wicked Toomey rep pipes, Dynojet kit,Zeel unit,Toomey Y boot filter.
927 smells nice, but from their website;
"For all carbureted 2-stroke gasoline engines; not intended for use in oil injection systems. Designed for high performance applications. Premix only formulation is safe for use at any OEM-recommended ratio. "
I guess I missed the best "injector oil" part.
- T.RexRacing
Ah most riders don't want to mess with premix. I've considered and repeatedly rejected that for a long time. Lazy when it comes to gassing up I guess.
Salvador Dali
Salvador Dali
Torco sucks for me!
- pushstartrearset
Premixing @ 24:1 has always been a safe ratio (good for high speed freeway cruising) for when I premix...you may have to rejet as necessary! I also like the smell of Redline Race Synthetic (very partial to this oil, when i could afford to run 24:1 in the AC 400F, it was definitely liking the high rpm freeway speeds @ 80+ mph. Amsoil has always burnt clean in the exhaust ports and a decent injector oil.
If you are someone that want's your ports cleaner than normal, I'd go w/ Amsoil (LC or AC bike).
Bardahl is alright (if available), iPone if you want to make the public happy (sweet scent when it burns) but having good luck with Amsoil. I pre-mixed 35-1 for breaking and bumped it up to 40-1 & smokes slightly. Good stuff and cheaper than iPone.
- IMG_3902.JPG (134.58 KiB) Viewed 1489 times
A link to some reading on oil for those interested.... you can spend days reading oil stuff
http://www.dragonfly75.com/motorbike/oil.html" onclick="window.open(this.href);return false;
