Hinson clutch and straight gear set
jimrd
#1 Post by jimrd » Sun Apr 01, 2018 1:07 pm
has any one tried the Hinson Clutch kit
I was particular looking at the straight cut gear set with the there hinson basket
I am not using the oil pump ,, I am blanking off
Also have all ready install the two stroke crank shaft and TZ roller bearings .. with the groove cut out on center bearing
or should I make my own gear set......
or do you know where I can get just the straight gear set
thanks
1964 Austin Cooper S 1071cc
1999 Ducati ST 4
T.RexRacing
Re: Hinson clutch and straight gear set
#2 Post by T.RexRacing » Sun Apr 01, 2018 2:36 pm
Cannot speak to the straight cut gears. I run a full Hinson in my '84 RZ350 filled with Barnetts plates/springs. Aside from a manly pull at the lever it's invisible. Cannot tell the difference from OEM. And I guess that's as good an endorsement you could get.
Salvador Dali
EE
#3 Post by EE » Tue Apr 03, 2018 6:41 pm
The only thing I don't like about the Hinson set up is their choice to use springs.. if anything you want to make the clutch as light as you can.. My choice for the best straight cuts is Liberty Gears. Ed
http://www.erlenbachracing.co" onclick="window.open(this.href);return false;
jimrd
#4 Post by jimrd » Tue Apr 03, 2018 7:31 pm
EE wrote:The only thing I don't like about the Hinson set up is their choice to use springs.. if anything you want to make the clutch as light as you can.. My choice for the best straight cuts is Liberty Gears. Ed
Do you have there contact number
Have you used them ?
I have tz roller bearing s so thinking straight cut gears !!
I am running no oil pump
Jim
1999 Ducati ST 4
