Need Torque value for Primary Drive nut RZ350
- Evans Ward
Could not find this in the factory service manual so asking here- what is the recommended torque value in ft lbs for the primary drive nut at right end of crankshaft? Also, blue locktite recommended? Thanks!
- Evans Ward
Re: Need Torque value for Primary Drive nut RZ350
If I had to guess, I'd say 65 ft lbs. Anyone know definitively?
- T.RexRacing
I'll check the manual when I get home.
Salvador Dali
Salvador Dali
- Evans Ward
Thanks Michael!T.RexRacing wrote:I'll check the manual when I get home.
Pretty sure it's 58 ft/lbs on the flywheel nut and the front sprocket nut.
- Evans Ward
Thanks Smoker!
- T.RexRacing
Cannot find my manual!!!
Salvador Dali
Salvador Dali
