PWK 28 Jetting Thread 2018..
JJH? N68X? NAPE? or what? (plz list mods per format in thread)
JJH
8
89%
N68X
0
No votes
NAPE
0
No votes
Other (specify in thread)
1
11%
Total votes: 9
Morty
Re: PWK 28 Jetting Thread 2018..
#16 Post by Morty » Tue Jul 17, 2018 12:21 am
Got them love them, yes the stockers can be set up good but the Keihins are just better, jetting similar to Bare's but one leaner needle JJJ?
75 RD350
83 RZ350
87 RZ350
03 KX250
78 DT175
nzminis
#17 Post by nzminis » Sun Dec 30, 2018 6:58 pm
Ive just been sorting out my pwk setup over the last week
few bits to fiddle around with , throttle cable is putting pressure on one carb causing it to open so need to fix that
but i went for the first ride today
stock 31k engine , pipes ,banshee reeds , full stock airbox , oil injection ,zeel but std , sea level
kx85 pwk
n68a needles from webike on 2nd clip from top
45 pilot
1 1/2 turns on air screw
tried the 138 mains but it wouldnt pull . Far to rich so i borrowed a few jets and tried a 120 and 118 just becuase thats what he had .
Now i know im going the right direction because it pulled nice
when i was revving it on the stand i did notice it did have a splutter at 5-6500 rpm
did some reading and someone said try a boost bottle . I just happened to have one on the shelf so slapped it on and the stumble was gone just like that !!
next thing is to buy a small collection of jet . 42 -4 0 125 115 etc just to be sure
Bare
#18 Post by Bare » Sun Dec 30, 2018 10:31 pm
Hmmm. 138's are TOO large... So is the 45 air, while 118's can lean your mixture into a seizure. But hey! Fill yer boots.
Fit JJH needles .. they work !
nzminis
#19 Post by nzminis » Mon Dec 31, 2018 12:57 am
Was just testing and running what i had and could get my hands on . I didnt want to spend few hundred $$ in jets and not need them
Went for another ride and its close , just miss matched mains dont help
45 is very good i cant fault it down low needle feels good aswell
guys in japan are running from 110 to 130 stock airbox . and 40-50 pilots with n68a(n80f) needles
totally dependent of fuel and where you are in the worl dont forget !!!
Bare
#20 Post by Bare » Thu Jan 03, 2019 5:53 pm
Awww c'mon.. Yess Genuine Keihin bits Ain't free So what?
Again 40 airs 130 mains and JH needles .. Work.
Try It !? then complain.
PWKS are V easy/user friendly to jet... they even tolerate goofy barely operable jettings.
Whole 'nother world better when you get them right though
nzminis
#21 Post by nzminis » Fri Jan 04, 2019 4:30 am
Local bike shops want $16 per jet !!
people want $50 us$ to send a small selections of jets across the world
so finding them at a decent price and good postage is hard
i do have some pilots and mains coming , will get some needles next time i need dirt bike bits , ktm freeride 250 uses 28s with j series needles
jjh $30 local each , added in my other bits $13 each
no rush , bike needs painting , just gathering bits and bobs !
Palolo
#22 Post by Palolo » Sat Feb 02, 2019 3:44 pm
I have a set of PWK 28's, haven't tried them yet. Where is a good source for JJH needles? I checked e-bay and amazon, didn't see them.
vmxwinn
#23 Post by vmxwinn » Thu Apr 18, 2019 1:56 am
I’m running JJH #2 clip, 45 pilots and 145 mains. Runs very, very clean and crisp. See my setup and tune in my signature.
Bare
#24 Post by Bare » Thu Apr 18, 2019 9:34 pm
Dunno... IF? using airbox and oem Airfilter 45 airs 145 mains and JH needles your are IMO running a Silly rich mixture (giving up too many horses .needlessly.
40's and 128's are better for Hard power usage.. as example DO check your plugs ...regularly.
PWKS run well.... even on Klumsy /inappropriate jettings.
But that doesn't mean you should :-)
PS.. Genuine parts Cost, either live with it or refit yer old Mikunis.
Whymee
#25 Post by Whymee » Fri Apr 26, 2019 5:53 pm
2.5 RZ350's
2018 Grom
2017 KTM 390
2017 FZ-10
1973 RT3
1974 TY250
plus many others
Palolo
#26 Post by Palolo » Sat Apr 27, 2019 4:41 pm
I went to the local moped shop and asked if he had PWK needles. The owner immediately asked JJH? Perfect, I got a set for about $12.
Bare
#27 Post by Bare » Wed May 01, 2019 8:05 pm
that reads as about right ....Watch Scooter guys carefully tho... they LOVE Fake Keihins.. and too often think there is no quality difference with the genuine bits.
nzminis
#28 Post by nzminis » Sat Jun 01, 2019 5:44 am
need to keep this post alive !
anyone else been plying with the pwks this year ?
ive moved on to a TDR250 and other things while my 350 is wating for paint
but i was happy with the testing i did before i pulled the bike down
in the mean time ive bought jjh needles and a good choice of jets
just looking through old posts becasue i might buy some more carbs for my Rz250 or Rd400
#29 Post by RuZty » Sat Jun 01, 2019 6:01 am
I started with Bares recommendation, 130/40/JJH and it works great, no need to change. Needle full lean, VF3 reeds, gutted air box with UNI filter, cut head, pipes and mild porting.
Bare
#30 Post by Bare » Sat Jun 01, 2019 11:31 am
Good :-) DO pull your plugs after a bit to double check the burn.
Uni filter may lean it it out a bit too much Or not .
Checking is good peace of mind tho.
