Piston Replacement
Yellow and Black RZ
Re: Piston Replacement
#16 Post by Yellow and Black RZ » Thu Jul 05, 2018 10:02 am
2cycle wrote:
Yellow and Black RZ wrote:If it was me, and the cylinder bore is ok, I'd verify what size the piston is and buy the same piston from the same manufacturer.
Would be a good idea to verify size but .25mm is .0098. Pretty tough to have much variation when the tolerances have to be so tight.
With that said pick up some bore gages and eliminate any fears you might have.
Do you mean make a request to the manufacture for a piston as close as the same size as the good piston or buy any 64.50 piston from the same manufacture ?
If the cylinder doesn't need a bore, then I would purchase the same piston and size as what was in there and install it.
'85 RRZ350 - Hacked.
