It is currently Mon Oct 22, 2018 12:37 am
Post new topic Reply to topic  [ 11 posts ]
PostPosted: Mon Aug 20, 2018 8:57 am
I noticed that after I ride my LC for longer trips, more than an hour - I will have transmission oil leaks underneath the kickstand leaning left. It is about the size of a quarter and takes about 30 min to accumulate and stops. Think it is shifter related. Anyone know what this might entail?
Thanks in advance.
Frank
PostPosted: Mon Aug 20, 2018 9:38 am
Shifter shaft seal. Dig out the old one, often with a wood screw and sled a new one on and tap in. Be sure to cover the shifter shaft end with Saran and remove all burrs on the shaft or you'll be redoing it again.
PostPosted: Mon Aug 20, 2018 12:22 pm
could also be the neutral switch o-ring.
:smt017
PostPosted: Mon Aug 20, 2018 4:18 pm
Or neutral switch itself. My plastic housing was cracked around the brass insert for the contact.
Still available from Yamaha.
My Bikes:
Yamaha RD500 1985
Yamaha RD350 1985
Yamaha R1 2001
Honda CBR 1000 2006
PostPosted: Mon Aug 20, 2018 7:44 pm
Tap the selector shaft's small alloy plugs in as well, if you lose one of those it will drip a small puddle overnight.
My Projects:
PostPosted: Mon Aug 20, 2018 10:00 pm
Hold on there boys. Lets not overlook the most obvious potential source of oil leaking on the left side of an LC. The countershaft sprocket seal is notorious for oil leakage and is much more common source than the shifter shaft seal.
Pull the left side engine cover and I bet you see streaks of oil radiating from the countershaft on the cases behind the front sprocket.
'81 RD350LC hybrid project bike - in pieces currently
'82 RD350LC in '81 colours - Built by "Solo 2" OEM pipes, UNI filters
'90 RZ350F2 with 31K motor, OEM F2 pipes & airbox
PostPosted: Mon Aug 20, 2018 11:17 pm
Thanks to all - it appears that the oil runs off the curve of the exhaust pipe. Bike leans left so gravity takes its course. Shifter shaft, bushings?
PostPosted: Tue Aug 21, 2018 12:12 am
You've made an assumption on zero evidence and appear to be running with that. Pull the left side engine case and have a look. That will tell you everything.
I've personally never seen a shifter shaft seal leak but I've had several countershaft seals leak.
Any leak that occurs on the bottom side of the engine will run down to the left edge and then drip onto the pipe. Its the nature of how things are arranged on an LC.
PostPosted: Tue Aug 21, 2018 8:43 am
Yup - your absolutely right. Gotta get into it to see.
PostPosted: Tue Aug 21, 2018 5:17 pm
Opposite here... I have had multiple shifter seals leak and a N switch. Never a countershaft seal.
:smt017
PostPosted: Wed Aug 22, 2018 12:50 pm
I've come across a few leaky shift seals - usually after the bike has been over & bent the shaft...
Users browsing this forum: No registered users and 7 guests
cron
