It is currently Mon Oct 22, 2018 12:47 am
Post new topic Reply to topic  [ 7 posts ]
PostPosted: Sat Sep 15, 2018 9:40 pm
Hi Guys
Can anyone tell me if the banshee shift drum will work with the RD/RZ350pv engine . seems they are still available
PostPosted: Sat Sep 15, 2018 11:13 pm
Dont know for sure sorry but I've used banshee shift forks in rz box/selector drum with nps.
PostPosted: Sun Sep 16, 2018 12:31 am
Should be the same I would think. Is it the same part number?
My Projects:
PostPosted: Sun Sep 16, 2018 9:19 am
Banshee is 2GU. RZ is 29L. But look the same on parts fiche...
PostPosted: Sun Sep 16, 2018 9:45 am
Shift forks and drive shaft have same pn, main shaft is different. I think the banshee gears Are wider? So would they require a different drum pattern?
PostPosted: Sun Sep 16, 2018 12:25 pm
I swapped just the shafts between the RZ and banshee leaving the original drum/forks in the case.
That works fine, so I strongly suspect if there'd be any difference required on the drum to run a banshee tranny, I'd have noticed.
Logically it should work using the banshee drum in the RZ.
The difference in the shafts is that the banshee runs different ratios in a couple of gears (5'th to 6'th for example is a bigger jump than on the RZ).
PostPosted: Sun Sep 16, 2018 12:30 pm
Thanks Gents..
All very helpful as always.
Users browsing this forum: No registered users and 8 guests
