It is currently Mon Oct 22, 2018 12:43 am
Post new topic Reply to topic  [ 9 posts ]
 Post subject: Useful Links
PostPosted: Tue Jan 22, 2008 11:46 pm
How 2 Strokes Work:
http://science.howstuffworks.com/two-stroke1.htm
2 Stroke Guide to Wisdom:
http://www.saltmine.org.uk/kgb/2stroke.html
Banshee vs RZ Cylinders:
http://www.geocities.com/kiwi_craig/Bnashee.htm >dead link<
RD-RZ-Banshee-TZ-RG Reed Cage comparison graphic (v2):
https://macshot.de/rd/Reed-Ventile.png
Gordon Jennings PDF's (2 Stroke Tuners Handbook and much more):
http://edj.net/2stroke/jennings/
Expansion Chamber Basics:
http://www.maxxtraxxusa.com/Tuned_Pipes_3608.cfm
Expansion Chamber Design Software:
http://buildandclick.com/
Mikuni Carb Theory 101:
http://www.iwt.com.au/mikunicarb.htm
RZ Teardown with Pics:
http://www.scooterhelp.com/RZ_help/rest ... start.html
RZ350 L (1984) and N-NC (1985) Factory Service Manual (pdf):
http://droxine.net/RZ/RZ350L-N-NC.pdf
YPVS Case Torque, Head Torque & PV Indexing:
http://droxine.net/RZ/YPVS-CaseTorque.jpg
http://droxine.net/RZ/YPVS-HeadTorque.jpg
http://droxine.net/RZ/YPVS-Indexing.jpg
Port Map (AC RD, LC RD, YPVS 31K/48H & 1UA):
http://droxine.net/RZ/RZ-RD-Ports.jpg
Oil Pump Adjustment for RZ & YPVS RD, RD250&350 (AC), and RD400 (AC):
http://droxine.net/RZ/RZ-YPVS-RD350-OilPumpAdjust.pdf
http://droxine.net/RZ/AC-RD250-350-OilPumpAdjust.pdf
http://droxine.net/RZ/AC-RD400-OilPumpAdjust.pdf
Angle to Distance (and vice versa) before TDC calculator (Excel xls):
http://droxine.net/RZ/2-stroke-timing-xen.xls
RZ/RD Specs (very complete for '80 to '95 models):
http://www.rd350lc.net/introduction.htm
SCRacing's Tech Pages:
http://home.earthlink.net/~scloughn/id16.html (compression, squish, and case assembly)
http://home.earthlink.net/~scloughn/id21.html (more thoughts on squish)
http://home.earthlink.net/~scloughn/id10.html (blowups ... ) >dead link<
350Bfine's RD250, 350, and 400 Electrical Schematics:
http://home.comcast.net/~todwatts/motorcycle_7.htm (scroll down to Useful Files ... about mid-page)
Yamaha Parts:
http://www.yamaha-motor.com/sport/parts/home.aspx
RZ/RD Used Parts:
http://www.motorcycle-parts.ca
Electrical Wiring (gauge table & current limits):
http://www.powerstream.com/Wire_Size.htm
Parker O-ring Handbook:
http://www.parker.com/literature/ORD%20 ... ndbook.pdf
If anyone has any useful links, put up a post and I'll include it here
1) 1984 Yam RZ350 w/ Spec II chambers, Zeeltronic, and K&N pods ... stock otherwise
2) 1984 Yam RZ350 awaiting '06 GSXR600 USD front, FZR400RR rear, & rev cyl's
PostPosted: Mon May 26, 2008 6:30 pm
2 STROKE WIZARD TUNED PIPE .... wow man ... i fly after this http://buildandclick.com/ is where i got my tuned pipe data from RD350 aircooled superbike ....EXPANSION CHAMBER EXHAUST DESIGN that work like nitro injection.... hehehehe
Charge it ...Supercharge it ....Turbo it ... Nitro it
 Post subject:
PostPosted: Sun Jun 15, 2008 6:56 pm
Thanks FF ... not a bad price for it at all. I'm eager to play around with it a bit.
 Post subject: Engine Teardown w/ Pics
PostPosted: Thu Jul 10, 2008 10:06 am
I found this today, lots of good pictures, would be a nice resource for someone tearing into an RZ350 motor for the first time.
'85 U.S. Model RZ350NCII
Stock barrels, no porting, 1st overbore, 125psi comp. Toomey re-issue pipes, 2-1 filter, V-Force 3 reeds, Stock VM26SS carbs, 30 pilots, Toomey garbage needle on 6th clip, 480 mains, Zeeltronic ignition - stock ignition curve.
 Post subject:
PostPosted: Mon Nov 30, 2009 9:23 pm
Good source for used RZ/RD parts (or anything, for that matter, except hardly davidson):
Good guy, have bought parts from them on and off for the last 15 years or so.
No affiliation.
'84 RZ350
4mm stroke, wickedatv stroker chambers and torque head 20cc
VM30 carburetors (270 main, 3/4 turn air screw), 2-in-1 Y intake
stg. II porting
"have a crappy weekend, i hope your house burns down." -carl brutananadilewski
 Post subject: Re: Useful Links
PostPosted: Mon Jan 27, 2014 4:52 pm
parker hand book (o-rings)
2004 BMW R1150RT
1989 FZR1000
1994 FZR1000
PostPosted: Fri Jul 31, 2015 7:54 pm
OK I'm still alive (woohoo) .. switched domain host .. droxine.net link working again. Noted dead links and added suggested links (thanks guys) and a few of my own.
PostPosted: Fri Jul 31, 2015 8:51 pm
Where the hell you been? Does it involve a parole board?
Salvador Dali
PostPosted: Fri Jul 31, 2015 9:34 pm
LOL ... hay T ... stayin out of trouble and dealing with the usual pitfalls of life. All those nice parts from england and elsewhere still waiting to be put on. I should be able to get 2006 GXR 600 (GSXR?) and up running gear for my USD forks at a decent price. But right now I can't even buy a thrill ... how you been?
Users browsing this forum: No registered users and 9 guests
cron
